cruze control???
Discussion in 'Motorized Bicycle General Discussion' started by thepolarpandabear, Jan 2, 2012.
  1. thepolarpandabear
    thepolarpandabear New Member
    Jun 11, 2011
    25
    Ok guys my right wrist hurts a lot from riding and other things (Hey you get your head out of the gutter). So is there any ideas for a cruze control. I've sat down and tried to design something on autocad but I'm stumped on this one.
    Also in the animations noone is wearing a helmet, just saying.xct2
  2. MonkeySeller808
    MonkeySeller808 New Member
    Sep 17, 2011
    29
    I thought I read some place that people use a grip shifter as a throttle so you can leave it at a different setting.
  3. frozenveinz
    frozenveinz New Member
    Sep 25, 2011
    161
    Or the cheap shifter choke lever on the CNS. If you've upgraded the carb, use that thing. However, cruise control of this type is very dangerous. On motocycles/cars the thing disengages on brakes, throttle, or some other input. TGhese will stay until you turn off, gotta be real carreful. And wear a helmet.
  4. andrewflores17
    andrewflores17 New Member
    Jul 12, 2010
    479
    ive had luck useing the shifter as a cruise control . sick bike parts sales them
    i wouldnt use it at high speeds and keep your crusie nice and slow .
  5. 2door
    2door Moderator
    Staff Member
    16,310
    I concure. Locking or otherwise defeating the spring return feature of the throttle is a dangerous thing to do. Yes, they have cruise control on some high end motorcycles but as Frozenveinz said, factory cruise control systems are very sophisticated and cancel out with break inputs and have an easily reached 'Off' button.
    In an emergency/panic stop situation you want that throttle to drop out 'NOW' not after you've fumbled around trying to move a lever on your handlebars.
    Don't do it.
  6. moonerdizzle
    moonerdizzle New Member
    Jun 28, 2009
    874
    Why don't you look for a motorcycle throttle with cruise control?
  7. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
  8. thepolarpandabear
    Jun 11, 2011
    25
    I could never figure how those would work with a twist throttle, I can understand how it would work with a lever system.
    What I'm probably going to do is notch out a u shape into the throttle and make a sliding catch to hold the throttle at cruzing speed. Once i get something drawln up ill post a .jpg of it on here.dnut
  9. Goat Herder
    Goat Herder Gutter Rider
    Apr 28, 2008
    6,251
    I have a aftermarket metal throttle. From leaning the bike on a wall etc thousands of times the throttle sticks in every position.
  10. thepolarpandabear
    Jun 11, 2011
    25
    [​IMG]
    I don't know if the image will be up loaded, I'm using a smart phone.
  11. professor
    professor New Member
    Oct 14, 2009
    501
    I use a bicycle lever type gear shift as a throttle. By adding a stop to the lever in an approiate place, the lever makes a fantastic thumb throttle. It naturally sits where my thumb lays on the bar.
    On the 79cc bike the center screw is lighty tightened to retain the throttle position, the engine doesn't have enough power to restrain the bike (Vbrakes) even if I forgot to back off the throttle.
    On the 212cc bike, the center screw is NOT locked.
    Either bike's throttle is totally better than any motorcycle/ atv or electric throttle control that I have ever used.
  12. GearNut
    Aug 19, 2009
    5,105
    They have a video on their site that shows it in action.
    But anyways here's how it works.
    It is held onto the throttle grip by friction. You must stretch it open to fit it over the grip. It works by allowing the palm of your hand to press against it rather than having your fingers wrapped around the grip all the time.
    You can relax your fingers and cruise just by simply resting your hand over the grip and paddle.
    The paddle is not intended to be adjustable on the fly (although doing so is extremely easy to do), you fine tune it's position while at a stand still (for safety reasons) then ride at the most common cruising speed that you ride at, testing if you set the paddle position correctly.
    It is really simple and surprisingly comfortable.
    #12 GearNut, Jan 3, 2012
  13. thepolarpandabear
    Jun 11, 2011
    25
    Well I guess that defeats my idea that I drew up earlier, thanks GearNut.dnut
  14. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    Why not simply change your throttle out for one that's comfortable? I don't like twist-grip throttles myself, so I used a trigger throttle.
    Mine came from a GoPed shop, but Staton sells the exact same trigger.
  15. thegnu
    thegnu New Member
    Sep 15, 2011
    982
    I saw an actual xcruize control on a older honda gold wing years ago was a very simple little thing attached to the grip , it had a fine tooth cog wheel attached to the inner edge of the grip an a spring loaded catch that would release if you rolled on the throttle . I hope this description helps , I have a perfect mental pic of it if ya want let me know an I will draw it to the best of my ability .
    Gary
  16. andrewflores17
    Jul 12, 2010
    479
    i was able to use a break lever off a old bike for throtle today little big but if you get one off a kids bike should work triger throtles are alot nicer compared to the twist type
  17. NunyaBidness
    NunyaBidness Active Member
    Jun 29, 2008
    1,062
    A buddy of mine and I used to pull the cable housing the throttle cable rides in, up and out of its resting spot in the top of the carb. We would move the housing to the side so that it rested on top of the place it was supposed to rest in. This gave us a good cruising speed and almost anything would make it go back into place and stop the cruise control action.
  18. Goat Herder
    Apr 28, 2008
    6,251
    Forgot to say it is a run of the mill twist grip throttle style .
