Couple Of Q's. Clutch Puller, Gaskets, Replacement Clutch Pads...
Discussion in 'Motorized Bicycle Trouble Shooting' started by dimentio, Mar 12, 2013.
  1. dimentio
    dimentio New Member
    Jan 5, 2013
    71
    Hey all, long time no see. I've been trying to keep tinkering with my motors in the hopes of becoming better. Lately my motor has been making a loud whirring (whining?) noise when I release the clutch. Is this a sign of having to replace the clutch pads? It's really loud, I can hear it over the motor... (Only sounds when the clutch is released, not held) Also, I bought a clutch puller to check out the clutch disk on a different motor. How does one go about using that tool? And my final question is, instead of buying a super expensive cylinder head to get better compression, is it possible to add an extra head gasket to add more space between the piston and head? Or is that the exact opposite of adding compression?
  2. dimentio
    dimentio New Member
    Jan 5, 2013
    71
    I would also like to know the purpose of a centrifugal clutch, and whether or not it is beneficial to have. I did a few searches on here but I can't find a cut-to-the-chase answer
  3. 2door
    2door Moderator
    Staff Member
    16,294
    11
    Welcome back. Glad you've returned and still riding.
    Noise: Have to lubricated the clutch actuating parts. The pin and ball bearing that goes in the engine drive sprocket? How about the gears on the right side? Worn clutch pads don't usually cause noise unles they are completely worn away in which case the clutch would slip so bad that it wouldn't pull the bike.
    The tool you have is not for removing the clutch parts. It's made to remove the drive sprocket. You only need a small screwdriver to disassemble the clutch to change pads.
    Adding a head gasket will decrease compression.
  4. dimentio
    dimentio New Member
    Jan 5, 2013
    71
    Ah I see, thanks. Do I need to remove the clutch disk (Not the outer one, the one that holds the actual pads) in order to replace the pads or can I do it with just the silver cover thing removed? And how about that centrifugal clutch? Is it worth having? And I guess from what you're saying, the less space the piston has between itself and the head, the more power, right? And I have one last question. My Voodoo muffler is spitting out this tan-colored liquid (Looks like liquid poop). Why is this? It's getting all over my rear forks....
    #4 dimentio, Mar 12, 2013
