I will not disclose where or the seller, but just explain why sometimes you just think the seller is just so dumb you cannot stand it. Actually really I contacted first on a different issue when I saw some liquid in a new carb I purchased. I was told it was part of the manufacturing process and is supposed to be there will not hurt anything. I found that to be true. The engine ran fine except I could not adjust the Idle with the screw that was supposed to contact the arm going to the butterfly valve. The screw could only tighten a short distance before the pointed end of the screw would hit the body of the carb itself. The screw also was not ever in a position to contact the butterfly valve arm if the screw were to compress the spring completely. The casting was made with severe issues that make the idle not available to do anything at all. The seller when contacted about this wants model number and pictures of the original carb I was replacing with the one they sold me. I mean why does it fly-ing matter. If the idle screw on this part they sold is of no use, who cares what you used before.. am I right. Maybe it is just the automated system if I can think that, but do not think so. Just that the sellers have no knowledge of what they sell, or are trying to tire me out... cheesh!
