Clutch travels too far in
Discussion in 'Motorized Bicycle General Discussion' started by andyKo, Jun 22, 2009.
  1. andyKo
    andyKo New Member
    Jun 22, 2009
    6
    Hi all,
    What a great forum. I'm just gonna dive in. Biking over the weekend the clutch seemed to not disengage. I re-adjusted the clutch cable, pushing in the arm and pulling cable slack out. Looks like the clutch arm is too far in before any clutch lever action. When clutch is pulled there still seems to be a bit of friction but I'm afraid to adjust any farther as the clutch arm may hit the other side.
    I've taken apart the clutch cover, there is a ball and rod. The parts don't look too worn down.
    What can I do to bring the clutch arm action back to normal working position? Is there any adjustments I can make? Is there anything in the clutch cover that can throw off the arm position?
    Picture1 shows how far it sits. Picture2 shows when pulling on clutch lever.
    thanks,
    Andy
  2. Denver Dave
    Denver Dave New Member
    May 26, 2009
    30
    The easiest way to remedy this would be to take the nut off the top of the arm, pull the arm off the shaft, and reposition it outward.
  3. reg454
    reg454 New Member
    Jan 11, 2009
    269
    Not necessarily if the arm is that far in than the pin is compressed and you will not get proper movement i say tighten the clutch up 1 turn and see how for out the arm is at. You can all ways undo the tightening if that does not help.
  4. Denver Dave
    May 26, 2009
    30
    Well, this begs the question from Andy - in your second picture, is your clutch lever pulled all the way to the handlebar? If the answer is "yes" then you need to tighten the spring as reg pointed out. If you have some more room to pull then repositioning the arm would be faster and easier.
    Also, is there any play in the lever before the arm engages? I know you said you removed slack but you can also adjust the barrel nuts on the lever side as well as where the cable attaches to the engine to fine tune the tension on the cable.
  5. andyKo
    andyKo New Member
    Jun 22, 2009
    6
    Thanks for the replies. You guys are too quick!
    Reg454
    thanks for the links.
    Denver Dave
    I'll try re-adjusting the nut on the clutch arm.
    then if that doesn't do it I'll try tightening the inner spring on my lunch break.
    Yes the second picture I have pulled the clutch handle right to the bikes handlebars.
    With clutch on handle released the clutch arm is pushed in as far as I feel it stop before there is weight to it.
    Andy
    Andy
  6. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    when clutch is disingaged the arm should be straight toward the back of bike.
    when clutch is engaged the arm should look like pic #1.
  7. wildemere
    wildemere New Member
    Feb 12, 2008
    269
    I had this problem once. Turned out to be a worn rod. The one that the clutch cam drives into the clutch.
  8. Mopedamauter79
    Mopedamauter79 New Member
    Mar 31, 2008
    254
    I would loosen the nut and let some cable out for some slack.
  9. Creative Engineering
    Sep 20, 2008
    1,668
    Andy,
    How many miles/hours are on the bike?
    Have you been adjusting the lever in gradually over the period of months, or did this happen suddenly?
    Jim
  10. reg454
    reg454 New Member
    Jan 11, 2009
    269
    Good question Manic
  11. andyKo
    andyKo New Member
    Jun 22, 2009
    6
    My guess would be about 1200 miles and 2years old. A daily commuter in summer. Average speed 37mph
    Extra details:
    26"wheel mountain bike, 36t sprocket, chinese 80cc. average
  12. andyKo
    andyKo New Member
    Jun 22, 2009
    6
    Forgot to mention my city has the worst roads. Our winters leave uneven pavement and large potholes. Most of the time biking I am constantly trying to avoid them but there are those large lengths of broken pavement that I have to run through.
    I wonder if the heavy jarring has possibly worn the main clutch rod as previously mentioned.
    I sort of missed out to mention in my first post that while biking during my ride I totally lost all clutch action. Biking toward a stop I go for the clutch and th lever just falls into the handlebar.
  13. Denver Dave
    May 26, 2009
    30
    1200 miles? Yeah, that probably would have been good to know. For some reason I assumed it was a fairly new engine.
    Take the arm shaft out of the sprocket cover and have a look at the flat part that pushes on the rod.
    Edited to add - just in case you didn't know, you have to turn the armature around to a specific position and it will slide right out.
  14. jpowers
    jpowers New Member
    Jul 10, 2011
    Sorry to bump such an old post, but has anyone ever been able to figure out the solution to this issue?
    My clutch lever is the exact same way, to a T! I tried it all, banging on the clutch side with a hammer, tightening/untightening the flower nut, tightening/untigethening the inner flower nut that controls clutch tension, replacing the stick that the lever squeezes and nothing does anything to the lever position. It's so deep in that there is no where for it to go anymore :(
  15. flmotorbikes
    flmotorbikes New Member
    Mar 23, 2012
    174
    I'Ve hit 2700 miles before on one
  16. Cavi Mike
    Cavi Mike New Member
    Dec 17, 2011
    189
    If the clutch camshaft isn't worn, the bucking bar is probably worn or maybe the ball shattered.
