clutch starts to engage while lever is fully pulled in after a long ride?
Discussion in 'Motorized Bicycle General Discussion' started by motor-bike80, May 11, 2015.
  1. motor-bike80
    motor-bike80 New Member
    Jun 14, 2013
    25
    hey guys, ive noticed that the clutch on my motorized bike starts to engage even when i adjust it to engage when i am about to fully let out the clutch lever, idk why its happening and it seems to only happen when the engine is hot but idk if thats the case all the time. has anyone experienced this issue? btw when this issue is happening the engine has a hard time idling and if i get off the bike and fully disengage the clutch while i lift to rear wheel off the ground the rear wheel starts to spin. thanks
  2. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,475
    44
    Did you adjust the flower nut to be free while the clutch lever is in the locked position?
  3. 2door
    2door Moderator
    Staff Member
    16,301
    25
  4. motor-bike80
    Jun 14, 2013
    25
    thanks, could it be that the screw in my clutch arm isn't tightened enough and the cable slowly slips through the clutch arm, i haven't got the stock screw that hold in the clutch cable, i lost it and i found another screw that fits the hole, lucky, but i cant tighten that screw all the way because i starts to slip but it hold the cable in tight enough i think, anyway, i am using a brand new clutch cable maybe its stretching but i also had this probelm with an old clutch cable. could it be because i am too harsh on the clutch? i doubt it, i think if that was teh case the clutch wouldnt engage as much,right?
  5. 2door
    2door Moderator
    Staff Member
    16,301
    25
    If you've followed the clutch adjustment procedures correctly then you might be right about the cable slipping/stretching.
    If you have a hobby shop near you you can find a good replacement for the cable stop. Ask for a 1/16" wheel collar. They are used on model airplanes on the axles to hold the landing gear wheels on. They typically have Allen head cap screws in place of the slotted screw that comes in the kit.
    Here's a suggestion: With a new or replacment clutch cable, leave the clutch lever in the locked (clutch disengaged) position when the bike is parked and not being ridden. This will hasten the cable stretch process so you won't have to do it as often. All cables will stretch a little. The force needed to actuate (disengage) the clutch is more than standard bicycle brake cables normally see. They will stretch a little and it doesn't take much to adversely effect clutch operation.
  6. motor-bike80
    Jun 14, 2013
    25
    thanks 2door, that's what i always do, i never leave my clutch disengaged when the bike is sitting, i always leave the clutch leave 100% released because that stops tension on the cable. i am also goign to order a clutch lock thing, its like the wheel collar that you suggested, it only cost 2 dollars anyway, thanks!
  7. motor-bike80
    Jun 14, 2013
    25
    do you guys know of any benifit you can get by changing the front sprocket of the engine? (the sprocket thats on the engine) like cam i get more torque or cand i get more speed by making it either bigger or smaller? i might be gettign a 60 tooth sprocket for my bike, what should i expect? will it do wheelies? how fast will it go? thanks
  8. maniac57
    Oct 8, 2011
    4,486
    No other size front sprocket is available for these engines.
    10tooth is it.
  9. Slogger
    Slogger Member
    Sep 8, 2014
    545
    I have the gear ratio program (available somewhere on this forum). I put in a 60 tooth rear, everything else standard, for a 26" wheel.
    You would have a drive ratio of 24.6 to 1 (man that's low)
    @ 7000 RPM you're speed would be 22 mph.
    I dunno about pullin a wheelie, but I guess it might.
  10. 2door
    2door Moderator
    Staff Member
    16,301
    25
    60 T on the rear might or might not allow 'wheelies' but you should be able to climb trees :)
  11. motor-bike80
    Jun 14, 2013
    25
    yeah even though the speed is low, i think torque is the most important factor because i like to climb hills, i think ill go faster though idk why, my engine revs high at top speed and it 3 years old
  12. Slogger
    Slogger Member
    Sep 8, 2014
    545
    I just pulled the 7000 RPM out of my hat.
    You couild go faster.
  13. motor-bike80
    Jun 14, 2013
    25
    yeah i think i should at least go 40 km/h but the torque is going to be amazing
  14. Slogger
    Slogger Member
    Sep 8, 2014
    545
    I ran it again, to get there you'll need to hit about 7700 RPM.
    Not too bad, that's doable I think.
    Good luck!
  15. motor-bike80
    Jun 14, 2013
    25
    thanks! what do you guys think about wheelies? will i be able to yank up the bars and giver throttle to get the front wheel up?
  16. crassius
    Sep 30, 2012
    3,475
    44
    maybe with an 80T sprocket, but the rest of us need to pedal a bit just to get it rolling
  17. fatdaddy
    fatdaddy New Member
    May 4, 2011
    1,516
    Yeah, like one of these.
    http://www.bikeberry.com/clutch-wire-clip.html
    fatdaddy.
