Clutch Problem
Discussion in 'Motorized Bicycle General Discussion' started by psifos, Jan 17, 2010.
  1. psifos
    psifos New Member
    Jan 16, 2010
    The clutch on my motor is not engaging the way it should. when I let out the clutch it doesn't start the motor but it still turns it doesn't lock the clutch in place. Can anybody help me?
  2. Homer
    Homer New Member
    Apr 20, 2009
    32
  3. psifos
    psifos New Member
    Jan 16, 2010
    Thanks but I have read that and found the problem to be either the clutch plate wasn't tight enough or the clutch pads were worn. Appreciate the comment though!
  4. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    is this that dis-engage the clutch and finger tighten the star nut thinggy
  5. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    That is what is sounds like. He also said he fixed it, but was not clear on exactly what he did. I guess he did the "star nut thinggy".
  6. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Idon kno....the plate not tight or worn pads ...i think turn the star
  7. heidimaria
    heidimaria New Member
    May 14, 2011
    Hello, directions please for a clutch that is not working properly - the plate pin does not push out. Not sure if the problem has anything to do with the cable or not. Thanks..:-||:-||
  8. GearNut
    Aug 19, 2009
    5,105
    Welcome to the forum!
    It would be nice if you could introduce yourself in the introduction section.
    In the mean time, I hope this can help you out.
    http://motorbicycling.com/f4/clutch-cable-clutch-adjusting-procedures-22726.html
