clutch is tightening after a ride
Discussion in 'Motorized Bicycle General Discussion' started by motorized kodiak, Nov 3, 2013.
  1. motorized kodiak
    motorized kodiak New Member
    Aug 3, 2013
    105
    hey everyone, my clutch gets tighter after a medium distance ride, it wasnt like this before, but now after every ride i need to adjust it, when i lock the clutch in the motor is half engaged and is about to die,how to fix this? and i lost the little ball for that goes in front of the clutch shaft but i replaced it with a short bolt, working fine, could that be the cause? thanks
  2. MotorBicycleRacing
    Jul 28, 2010
    5,686
    27
    The "little ball" is a 8 mm ball bearing.
    #2 MotorBicycleRacing, Nov 3, 2013
  3. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    The bearing is important. It is the only thing in there that prevents the release "bucking bar" from rotating and grinding up the whole release mechanism assembly.
    Another thing that could be causing the adjustment to go out of whack is that the clutch cable is stretching.
    This is normal for any cable but the cheap quality ones do it more that good quality ones. They all stretch a bit at first until they settle in to a working length then mostly stay at that length for the rest of their working life span.
    What cable are you using?
    Also, is the cable end ferrule slipping on the cable?
  4. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,075
    I did not know that.laff
  5. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    I have the same problem, only mine is directly related to engine heat. :D
  6. 2door
    2door Moderator
    Staff Member
    16,301
    26
    ???????????????? Engine heat?
  7. Venice Motor Bikes
    Mar 20, 2008
    6,170
    Do you have the little 'set screw' installed on the flower nut on the main clutch plate??
  8. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,511
    48
    if the clutch is slipping just a little, then the pads may swell a bit during a ride
    try going up a steep hill and check for slippage
  9. dodge dude94
    Jun 8, 2012
    1,017
    Yeah, after a long ride, when then engine is super hot the clutch drags.
  10. maniac57
    Oct 8, 2011
    4,486
    I'm guessing the problem is your ball replacement "bolt" self-destructing while riding allowing slack to develop.
    Replace the lost ball with an 8mm bearing and be sure the bucking bar is not already worn down.
  11. 2door
    2door Moderator
    Staff Member
    16,301
    26
    And lubricate all of the clutch actuator parts well with a good grade of bearing grease. This is a step many neglect and suffer the same symptoms you have because of it. Oil or WD-40 won't do the job.
  12. Intrepid Wheelwoman
    Intrepid Wheelwoman New Member
    Oct 29, 2011
    2,831
    I owned a Francis Barnett with a Villiers engine during my twenties and the gearbox design used a very similar way of operating the clutch. When I first got the bike I had problems with the operating rod being too short due to wear so I added a second ball bearing as a temporary fix. As it happened it became one of those temporary fixes that ended up being permanent and when I finally sold the bike (like an idiot) it still had the same two ball bearings in place on the end of the operating rod.
    Mind you the Fanny-Bee used a cork lined wet clutch and with the British approach to automatic exterior lubrication of the engine and its immediate environment there was never any problem with the operating rod lacking for lubrication.
  13. maniac57
    Oct 8, 2011
    4,486
    "Automatic exterior lubrication"
    I choked on my tea laughing I.W.!
    I would bet a thousand dollars there is still an oil spot on the garage floor of my childhood home from the first Norton Commando I inflicted on myself in my teenage years.
    People would back off behind me when the oil started spotting the windshield of the following driver...
    Good times!
  14. 2door
    2door Moderator
    Staff Member
    16,301
    26
    It is a well known fact that all British vehicles leak oil. It is also known that the electrical systems in British vehicles leak smoke. And as you know, if you let the smoke out of an electrical system it will cease to function. Never, ever let the smoke leak out of a major electrical component such as a starter or battery. They hold a lot of smoke and when it comes out, you'll know it. Lucas saw this as a problem and offered this fix for those who inadvertently allowed the smoke to leak out of their electrical systems.
    What this has to do with a tight clutch, I don't know. Just thought I'd stick it in here.
    EDIT: Apologies to our British members and friends. Just poking fun from across the pond. No offense intended. :)
    #14 2door, Nov 5, 2013
  15. maniac57
    Oct 8, 2011
    4,486
    Lucas: The King of Darkness.
  16. Intrepid Wheelwoman
    Oct 29, 2011
    2,831
    Which explains why most of my old bicycles have Miller electrics, - or Bosch. :D
    A Norton Commando? - cool. My big Brit bike was a Matchless single banger, - another bike which I never should have sold (sigh).
  17. dodge dude94
    Jun 8, 2012
    1,017
    Since we're talking about smoking wiring, I burnt up the already non-working radio in my 76 when I let it ground another wire that was not supposed to be hot. :D
    *POOF!*
  18. maniac57
    Oct 8, 2011
    4,486
    That's not the same dodgedude.
    The british stuff would do it without being touched, usually at the best possible moment to ruin your day. Just random failures whenever.
    Still, when it ran...ahhh when it ran!
  19. dodge dude94
    Jun 8, 2012
    1,017
    lol True. I was just throwing in my experience on the subject since this thread has been derailed. :D
  20. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Derailing threads can be fun sometimes. No problem, Dodge. We all do it and I'm as guilty as anyone. As long as it brings a smile, it's all good. :)
