Clutch cable is snapped, What do?
Discussion in 'Motorized Bicycle General Discussion' started by bwayney, Jun 28, 2011.
  1. bwayney
    bwayney New Member
    Jun 28, 2011
    I bought my motor bike from a guy off craigslist about 1 year ago. I drove it and parked it at a taco bell and after Im done i see my clutch cable has been snapped(The brake line that goes from the left handlebar to the engine with the clutch i believe).
    Anyways i have no idea how to fix this or where to get what looks like a normal brake line that is used for the clutch cable. I can sometimes manually get the bike to by holding in the clutch allowing me to pedal and then releasing the clutch and then hoping it runs. But it sat for a while and i can no longer get it to run.
    Is there anyone in the Grand rapids area(Michigan) that can help me or know where i can bring this bike to get fixed, i really miss riding it. Thanks alot.
  2. jburr36
    jburr36 Member
    Jul 17, 2008
    284
    We can probably give you all kinds of ideas on what to do but what would greatly help us is if you uploaded some pics of it. We have no idea what kind of engine or clutch system you have and there are many different kits out there. Help us so we can help you.
  3. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    You should be able to get a standard brake cable at any bike store or a well stocked general store. Get the longest one you can.
    Then measure the length and cut off the sheath (pull the wire out first) put the wire back in, connect to the lever, thread through the anchor to the lever on the motor and secure.
    Easy. Should take 15 minutes and cost 5 bucks.
  4. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    Yes....China Mart (Wal Mart) has a assortment of cables in a 3 pack for around $6.00... Where did the cable break....at the guide in the engine valley?
  5. bwayney
    bwayney New Member
    Jun 28, 2011
    Attached are the photos of what im talking about.
    In the first photo is the brake line/tube that is snapped.
    In the second photo is what i think the clutch is, i have to hold this back which is hard to pedal the bicycle otherwise the backtire just skids and stays put.
    in the 3rd photo is the left handlebar that part of the clutch cable goes to.
      File size:
      28.5 KB
      189
      File size:
      30.4 KB
      172
      File size:
      28.4 KB
      188
  6. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    First photo is the clutch cable.
    Second photo is the clutch release arm.
    Third photo is the clutch hand lever.
    Any quality bicycle brake cable can be used as a replacement for your broken clutch cable.
    In fact, most brake cables sold at bicycle stores are much better quality that the cable that comes with the engine kits. Try to get one with a teflon liner inside it. It will greatly reduce the effort required to operate the clutch.
    If you can get a teflon lined cable, do NOT oil it! It does not need any additional lubrication.
    The installation of the cable is pretty much straightfoward. If you can thread laces into a shoe, you can change the cable.
    Scroll down to Step 4 in these instructions if you want to:
    2-Stroke Engine Kit Installation
  7. Al.Fisherman
    Sep 9, 2009
    1,966
    First of all if it isn't the clutch arm when disengaged should be parallel with the bike frame. As far as the cable housing it needs to be the correct length from the handlebar to here the clutch stop is. Here are a few pictures..You can see the routing of the cable, these makes it easier to pull on the clutch handle, and the cable is not in a bind.
    [​IMG]...[​IMG]...[​IMG]
  8. bwayney
    bwayney New Member
    Jun 28, 2011
    how do i know what size cable to get and how long?
  9. GearNut
    Aug 19, 2009
    5,105
    They only come in one size, and you have to cut the housing and the inner wire to proper length yourself. I recommend using sharp cable cutters, not small wire cutters.
  10. Al.Fisherman
    Sep 9, 2009
    1,966
    #10 Al.Fisherman, Jun 29, 2011
  11. jburr36
    jburr36 Member
    Jul 17, 2008
    284
    I bought an itty bitty mini bolt cutters from Harbor freight. They cut those cables, steel wound sheeth and all just like a pair of wire cutters cut through a wire. So effortless. Also what I was doing to keep the wire from unravelling was to put a small ball of JB weld on the end. The worst thing about biking for me was constantly getting stabbed in the legs by some frayed steel cables sticking out of the bike. **** I hate that.
  12. otheracco
    otheracco New Member
    Jul 19, 2010
    33
    That's a great setup (in pictures 2 and 3), but where did you get the parts? Instructions would be great because my clutch cable broke at the 'far' end of the engine mounted bolt. Obviously I need a setup with a lesser angle between the bolt and the clutch arm.
    EDIT: It looks like you made the part yourself. I don't have a welder, is there a way to make the part with only regular household tools?
    #12 otheracco, Jul 21, 2011
  13. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    I use a fwe drops of superglue on the cable before I cut it with sharp kliens. Soaks right in and sticks em together.
    After cutting the sheath, I unflatten the hole with a pick
    I run the cable thru a little grease in my hand as I re-insert the cable.
    Greased or oiled cables are much easier to use and it extends their life.
    Been my experience that most cables eventualy get corrosion if they aren't lubed.
  14. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    Yep, sharp cutters are very important! I recommend getting "slick braided" cables and using a bit of lithium grease.
    I have 4 cables at handlebars, soon to be 6! lol
    #14 The_Aleman, Jul 21, 2011
