Clutch Ball Bearing
Discussion in 'Motorized Bicycle General Discussion' started by fischer550, Apr 4, 2014.
  1. fischer550
    fischer550 Member
    Mar 24, 2014
    234
    Hey guys, I was working on my clutch, and the ball bearing fell out. Where Exactly does it go? I don't know where it fell out of exactly. Thanks!
  2. sublunacy
    sublunacy New Member
    Sep 12, 2013
    90
    did u get a manual? maybe look at grubeeinc
  3. sublunacy
    Sep 12, 2013
    90
    goes ball then plunger then cover.
  4. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    The shaft that the drive sprocket is on is hollow, whenever you took the cover off that the clutch arm is in, you seen the shaft/bucking bar, as sublunacy has said, put a good dab of thick grease all over the ball, put it back inside the hollow shaft, put some thick grease all over the bucking bar, slide it in behind the 8mm ball bearing, then make sure there a good dab of grease where the clutch arm contacts the bucking bar and then bolt the cover back on and bingo.....you got-er-done..!
    Map
    .wee.
  5. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
  6. mapbike
    Mar 14, 2010
    5,380
    Excellent GearNut........ I had forgot all about all the old pix by Manic.... that is some good stuff, seems we should have a sticky with all those pix together for the noobs and those who are real confident with how everything works and where it all goes if they happen to do a tear down and forget how something should be.
    Map
  7. GearNut
    Aug 19, 2009
    5,105
    I have bookmarked the pix of that and the clutch. I wish I could find the animations he generously did and bookmark them too.
