clutch arm position
Discussion in 'Motorized Bicycle General Discussion' started by papirican71, Jan 9, 2011.
  1. papirican71
    papirican71 New Member
    Sep 7, 2009
    7
    is there anyone who could tell me (hopefully with pics) what position the clutch arm should b in with the leaver [pulled in and with the lever released? i would greatly appreciate help with this. thanks
  2. matthurd
    matthurd New Member
    Dec 13, 2010
    817
  3. breno
    breno New Member
    Aug 19, 2010
    411
    The pic on the left shows the lever inline with the motor disengaged.
    And the lever at the 5 o'clockish position is the lever in engaged.
    Hope this is what you were after.
    Good luck let us know what you found.
  4. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    Clutch arm position alone isn't the most accurate way of determining proper setup as it's a bit inconsistent & ya really need only insure there's no slack in the cable but no real tension when the lever is released.
    The clutch actuator arm is on a splined shaft, but it's not always pressed on in the same position from engine to engine - in fact I remove mine and turn it in a spline or two to help prevent it catching on my pant leg *shrug*
  5. 2door
    2door Moderator
    Staff Member
    16,308
    30
    This is backwards. Engaged (clutch allows engine to drive sprocket) the lever will be as shown in the left photo. Conversely, when the clutch is disengaged, handlebar lever pulled in, the engine is disconnected (disengaged) from the drive.
