Cleaning/Lubing Freewheels
Discussion in 'Motorized Bicycle General Discussion' started by 5-7HEAVEN, Jun 20, 2013.
  1. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    37
    How do you guys clean & lube your freewheels? My chainring freewheel needs maintenance. I flushed it out and tried to push grease thru the cracks.
    How do you guys lube freewheels?
  2. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Are you talking about a crank free wheel like used with a shifter bike set up?
    if so I dont have a shifter bike so my knowledge on this is very limited, I will say though that if there is a gap that will allow it to be oiled, I would possibly get me a can of spray grease, a Napa parts store or most industrial supply stores like Motion Industries will have the spray grease, it is a somewhat regular red grease normally but it is desolved in a solvent that will allow it to be sprayed into small gaps between surfaces and into bearing and such, after it has been sprayed into an area you have to let the piece sit for a little while and the solvents with evaporate and leave the good thick grease behind, this might be the answer to what you are needing to lube.
    Here is a link to a good deal on what I'm talking about on Amazon.com, very good price on this.
    Product Description
    BIG REDTM - FPPS Multi-Purpose Red Grease BIG RED is a highly efficient lubricant in an easy to use spray can. This product sprays out as a thin, penetrating liquid and sets as a thick, red grease. The grease withstands temperatures to 500°F and resists "throw-off" from moving parts. Included in the formula are additives for antirust, antiwear, oxidation and for water and acid resistance.
    http://www.amazon.com/dp/B009LMVBU6...e=asn&creative=395105&creativeASIN=B009LMVBU6
    Hope this helps, Map
  3. BigBlue
    BigBlue New Member
    Nov 29, 2011
    781
    Here's a video from ThatsDax on how to service your freewheel - repack and service: http://thatsdax.com/INSTALL_AND_SERVICE_VIDEOS_PAGE.html
    There are a lot of ball bearings, so it is a good idea to take apart the freewheel on a level and light colored cloth - just don't loose any!
    Good Luck,
    Chris
    AKA: BigBlue
  4. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    Thanks Chris and mapbike.
    I had a left-hand freewheel disintegrate on me years ago.:-||
  5. mapbike
    Mar 14, 2010
    5,380
    You're very welcome 5-7.........
    Hope you get things squared away and back in tip top working order with some fresh lube and a clewned up clut h bearing.
  6. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    I watched Dax's videos regarding freewheel maintenance and shift kit installation. Those videos were very informative. I'll be cleaning/lubing this weekend..bld.
  7. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,566
    58
    I've had a LOT of high miles/high speed customers that have worn the freewheel pawls down to nubs - easier to just throw a new one on than to rebuild - no amount of lube will help that click click click at those speeds/distances.
  8. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    I have spare freewheels.
    I'll be maintaining what's on my bike until it's time to replace it.
  9. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    On my shiftkit I've got White Industries Trails freewheels. They're very easy to take apart and service. Good part is no small bearings inside of them. Bad news one of them is about $100.
  10. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    I have one of those, but the rest are generic ones.
  11. LR Jerry
    Dec 19, 2011
    1,027
    #11 LR Jerry, Jun 21, 2013
  12. maniac57
    Oct 8, 2011
    4,486
  13. 5-7HEAVEN
    Aug 2, 2008
    2,364
    37
    LOL, that's how Dax opened his freewheel on his video.
