chopper.....er
Discussion in 'Motorized Cruiser Bicycles' started by bottledViolence, Jan 12, 2011.
  1. bottledViolence
    bottledViolence New Member
    Jan 4, 2011
    20
    my plan is to build a bike that kind of looks like an old chopper like the one in the first pic so i started with this red bike which i have no idea what it is and put chrome drilled forks on it and some riser bars then cut the seatpost down. then i remembered i had a set of occ chopper forks soi threw them on to give it more of a motorcycle look
  2. bottledViolence
    Jan 4, 2011
    20
    then once i got the forks on i realized they were a little too long for my liking so i chopped them down and welded a washer and nut to the end of each tube. while i had the bike to a bare frame i painted it black and put a schwinn crank in it and repacked the bearings. i also found a set of chrome bars. i just ordered a quick and thick brick so for now it sits with mountan bike tires and the fender was free from a bike shop (cause they said it was yellow)but im gonna paint it along with the tank in a nice heavy flake.my raw kit just came today so ill start tearing into it and do some porting next
      File size:
      271.5 KB
      116
      File size:
      360.9 KB
      145
      File size:
      260.6 KB
      File size:
      386 KB
      261
  3. Bike Monster
    Bike Monster New Member
    Jun 4, 2010
    377
    looks cool! i am definitely
    following this build...
    usflg
  4. bottledViolence
    Jan 4, 2011
    20
    i found a set of mini apes and put them on and i think it looks better and i also sanded that awful yellow off the fender and i might just put some clear over the bare metal. also painted some flake on the tank and some fish gills.it was a quick spraycan job that ill probably redo once the bikes all done
      File size:
      339.5 KB
      160
      File size:
      259 KB
      150
  5. Bike Monster
    Jun 4, 2010
    377
    looking good!.flg.
  6. bottledViolence
    Jan 4, 2011
    20
    i got my tires and mounted them and the back ended up being WAY too big for the frame so i made a few cuts and spread the triangle and now i just have to weld it up on the bottom and weld a spacer in on top
      File size:
      306.1 KB
      136
      File size:
      416.1 KB
      151
      File size:
      308.4 KB
      119
      File size:
      315.4 KB
      117
  7. ezheimers
    ezheimers New Member
    Jan 2, 2011
    57
    Looks like you are willing to 'jump right in' and tackle whatever it takes...
    Keep us up-dated on this build............ -EZ
  8. bottledViolence
    Jan 4, 2011
    20
    when its -6 degrees out side gotta have something to do to NOT be outside so why not cut weld and cut and weld
    .weld
  9. bottledViolence
    Jan 4, 2011
    20
    i dicided to make a chrome air cleaner from an old oil breather for a car. i cut the tip off it and put 2 nuts inside and just ran the screws from the other side of the carb then started polishing the engine covers
      File size:
      266 KB
      83
      File size:
      568.3 KB
      104
      File size:
      313.9 KB
      96
  10. Bike Monster
    Jun 4, 2010
    377
    i like those wheels!
  11. bottledViolence
    Jan 4, 2011
    20
    so i got the rear triangle welded back up and made offset mounts for the motor
      File size:
      60.5 KB
      75
      File size:
      71 KB
      File size:
      55.3 KB
      82
  12. bottledViolence
    Jan 4, 2011
    20
    then i started putting everything back together and made an exaust out if some olf motorcycle scraps. i still have towire up the lights put on a front brake and attach the rear fender. when going forward the chain is fine but when going backwards it pops off for some reason
      File size:
      65 KB
      171
      File size:
      74.3 KB
      156
      File size:
      62.4 KB
      128
  13. Bike Monster
    Jun 4, 2010
    377
    WOWIE! that exhaust looks sick!!!!
  14. vintage97302
    vintage97302 New Member
    Feb 3, 2011
    89
    That tank paint is bad ass man..shft.
  15. bottledViolence
    Jan 4, 2011
    20
    i definately need to put more clear on it its still gritty from the flake under it
  16. F_Rod81
    F_Rod81 Dealer
    Jan 1, 2011
    1,033
    looks similar to what I'm building, mine should be done by the end of the month.
  17. bottledViolence
    Jan 4, 2011
    20
    i started it up last night and it was SO loud i might put some sort of baffle in the exaust
  18. Bike Monster
    Jun 4, 2010
    377
    you could try some steel wool...
  19. fall_down_stand_up
    fall_down_stand_up New Member
    Apr 26, 2009
    555
    What happened to this guy doing the build,I was all excited to follow this thread and then he just disappeared....
    John
  20. bottledViolence
    Jan 4, 2011
    20
    lost my internet.......but im still working on the bike and ended up buying a new frame
