Chain Tensioner Enjoys ripping up tires!
Discussion in 'Motorized Bicycle General Discussion' started by Chrismbello, Jun 20, 2010.
  1. Chrismbello
    Chrismbello New Member
    Nov 8, 2009
    39
    Anyone else hate these stock tensioner. They just went through 2 wheels of mine (one of which is 100$) and broke the spokes. I will probably be buying a new back wheel soon and bolt the tensioner into place because I don't know how to fix spokes like this. Anyone know of wheels that work well for them with the motorized kits?
    How many wheels of yours have been destroyed by these blasted tensioners??
    -Chris
  2. robin
    robin Member
    Nov 15, 2008
    616
    Mine was destoyed so i then drilled a hole in the frame so the tensioner wont rotate.
  3. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
  4. Chrismbello
    Nov 8, 2009
    39
    That's what I plan on doing, as I finally have learned my lesson. I'm surprised the kits don't tell you to do that in the first place.
  5. asianflava
    asianflava New Member
    May 13, 2010
    57
    Right out of the box, it looked a bit questionable, mine didn't even line up with the chain. I just made my own out of a piece of flatstock and Adel clamps. I used the roller from the kit tensoner.
  6. nidyanazo
    nidyanazo New Member
    May 25, 2010
    316
    Yes I agree, that's the way to go w/ stock tensioner.
  7. klb6154
    klb6154 New Member
    Jun 20, 2010
    76
    dont know how well this will work yet i had problems with my scwinn riverside and i sold it before i perfected the chain tennsioner my new bike is a huffy cranbrooke i used a set of rimms from a 11987 murray street bike that i litteraly found on pittsburghs route 579 the shifter from the same bike and the brakes the main reason for the huffy frame is that the rear is the same size as the antique ten speed rim and axel same on the old mbs but the frame is slotted frame allowing me to adjust the motor chain by moving the rea wheel and the spring loded shifter handels the chain on the pedal side so i can pick the best gaer to run depending on how i choose the exaust im 265 pounds so i do have to help alot on the steep hills of pittsburgh and i know longer need the chain tensioner on the motor side as i can make it as tight or loose as i want by moving the rear wheel i willl
  8. klb6154
    klb6154 New Member
    Jun 20, 2010
    76
    my bad im new to all of this computer crap but i will let yo know next week when i have time to make the final adjustmentsa
