chain rubbing...help
Discussion in 'Motorized Cruiser Bicycles' started by oldsurfer, Jun 8, 2010.
  1. oldsurfer
    oldsurfer New Member
    May 21, 2010
    126
    i recently bought a migari...however you spell it tahati
    put on a 70cc grube bought the manic mechanic kit sproket and hub adapter...chain is right against the tire...any suggestions??????????!!!!!!!!!!!!!!!!!!!:-||
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    Can you mount wheel sprocket farther away from the wheel?
  3. Bikeguy Joe
    Jan 8, 2008
    11,529
    Thinner tire?
  4. sojudave
    sojudave New Member
    Oct 18, 2008
    189
    1: Have you tried to slide the adapter over?
    2: How wide are your tires?
    3: Is the manic sprocket dished? If so try flipping it over.
    4: Is your wheel centered between the chainstays?
  5. oldsurfer
    May 21, 2010
    126
    If I Move It Over It Rubs On The Lover Frame Arm..i Am Messind With The Tensioner.....for All You Guys That Don't Want A Chain Tensioner....it Seems If I Move The Tensioner Way To The Back I Have Clearance...just Got My Firebelly Tensioner Kit...hope This Solves The Problem...as For Tire Size I Have Size That Came With The Tahiti Bike
  6. oldsurfer
    May 21, 2010
    126
    i fiwed the problem with the help of piston cycles...installed new hub with internal drum breat ...it required me to spread the rear forks which gave me the clearance i needed ....now i have a manic mechanic sproket and adptor which fits the micagri bike will sell it for $40..contact me...was never used.bf.
