Chain Alignment On Wider Axles
Discussion in 'Motorized Bicycle General Discussion' started by chicagoschwinn5, Dec 18, 2009.
  1. chicagoschwinn5
    chicagoschwinn5 New Member
    Sep 14, 2009
    13
    I have a atom hub and have just about completed the modifications to get rolling. A buddy says that because the rear axle is wider. the front sprocket on the motor and the rear sprocket do not line up and he feels this could be hazardous at high speeds. How far off can the rear sprocket be and not throw the chain.
  2. Venice Motor Bikes
    Mar 20, 2008
    6,170
    If the chain still clears the inside of the frame, it will work!!
    Just build it! The sprockets don't have to be perfectly in line with each other. (trust me!)
  3. captainrichhill
    captainrichhill New Member
    May 31, 2008
    203
    Maybe you could set the engine off-center or twisted in the frame so they line up better. It sounds like the front would have to be more to the right or the back mount more to the left. That would align the sprockets at a better angle.
  4. Venice Motor Bikes
    Mar 20, 2008
    6,170
    You can't really move the engine to the side because the pedals will hit it. :(
  5. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    You cant move the engine over but you can use a spacer and move the rear sprocket over so the chain lines up with engine and rear sprocket. plus you can use the chain tensioner to help line up the chain.
  6. captainrichhill
    May 31, 2008
    203
    The problem was that his rear axle was TOO WIDE. Where would you put the spacers?????
    I shifted the whole engine over about 3/16" so that the chain would clear the tire. That's how I did it maybe I did the impossible.
