Carb overflowing/leaking. What other maintenance should I do while I'm at it?
Discussion in 'Motorized Bicycle General Discussion' started by Mind_Reader7, Sep 28, 2010.
  1. Mind_Reader7
    Mind_Reader7 New Member
    May 1, 2010
    393
    Well I went outside and half my my fuel is all over the ground. So I turned off that petcock and will let it dry before fixing the carb. Any other routine maintenance I should do while I'm at it?
  2. 2door
    2door Moderator
    Staff Member
    16,301
    26
    Its always a good idea to turn the fuel off when you're not riding. The float and needle valve 'should' keep fuel from flowing, nevertheless even the smallest piece of crud in the needle valve will keep it from closing completely an allow fuel to flow into the bowl. That, and an improperly adjusted float level will also promote fuel flow when you don't want it.
    As for preventative maintenance; keep your tires inflated, chains lubricated, check all critical fasteners regularly (don't over tighten them) Brakes, bearings and frame integrity. Use clean containers for mixing your fuel and install a fuel filter upstream of the carburetor. Use common sense and keep your eye on the things you know are important.
    These will go a long way in keeping you on the road and running reliably.
  3. Mind_Reader7
    May 1, 2010
    393
    Well I just fixed my carb. Didn't seem to be anything wrong with it, still cleaned it/bent the float tab a bit.
    While I was at it, I remounted my engine (it was on a pretty big lean), adjusted my chain (still need to oil it, any recommendations?), changed the stock head to a slan head I had laying around.
  4. Mind_Reader7
    May 1, 2010
    393
    Wow, went pretty awesome. However my clutch seems to be making a small sound, I'm not sure if it's always been there. I took the side off the clutch, and my guess is it's because the big gear seems to be a tiny bit loose. I can't tighten it anymore, but I don't think it should be a problem.
  5. Mind_Reader7
    May 1, 2010
    393
    Just spent $40 on chain/masterlink/half link. I cut it 1 link to short.
    Get more chain tomorrow I guess D:
  6. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    D'oh, well if you ever move to a smaller sprocket that chain will still be good for something. :) For oiling it, good'ol clean motor oil is your cheapest option. You could spend some bucks on "chain lube" but re-oiling once a month is cheaper, eh. Plus its a good reminder that it's time to inspect everything too, motor mounts, leaks etc.
    A little clutch noise is expected, you can apply a small amount of grease to the gear to reduce the 'whine' sound, just don't over do it(for obvious reasons). Also, people have had luck gluing an old mousepad to the outside of the cover.
    btw, did your leak stop? As Tom said, you should turn off fuel when not riding anyway... but we humans are forgetful sometimes... :)
    gl.
  7. Mind_Reader7
    May 1, 2010
    393
    Yeah, my leak stopped. I'm not sure what the problem actually was, there was no rubbish stuck in it. I just soaked it in hot soapy water/rinsed it real good with cold water, then bent the float tabs a tiny but. I also changed the the needle thing to 2nd from the top, it was on 3rd, and there are 5 spots.
    Still kinda annoyed about the chain though. I'm using a 38tooth btw, so I don't see then chain being used on my bike. I might find someones bike who can use it though.
  8. Mind_Reader7
    May 1, 2010
    393
    Hey, I also noticed the clutch pads seemed burnt? The clutch had been slipping from time to time, nothing major though.
    I'm going to buy some new pads anyhow.
  9. killercanuck
    Dec 17, 2009
    1,749
    Cool, hey you can get a few more miles out of your pads by scuffing the friction surface with 320+ paper, don't forget to tighten your flower nut a few notches after.
    What did your plug tell you before moving the C-clip? Remember, a nice chocolate brown is what you want.
    gl.
  10. bairdco
    Aug 18, 2009
    6,350
    25
    for less than a chain, you can buy a good chain breaker tool. then, if you make it too short, you can put it back together.
  11. Mind_Reader7
    May 1, 2010
    393
    It was a bit darker than chocolate brown. However it has a lot better throttle response now anyhow.
  12. Mind_Reader7
    May 1, 2010
    393
    Well, I still got about a foot of chain left. How does a chain breaker work? Could I use it to join the 2 pieces?
  13. killercanuck
    Dec 17, 2009
    1,749
    Hells yea! If the chain you're trying to link is the same width use the breaker to 'lock the pin' in place. Just like when cracking a pin, only you're sealing the pin with the breaker.
    How to Use a Chain Breaker | eHow.com
    gl.
  14. highlander9
    highlander9 New Member
    Oct 15, 2010
    74
    when breaking chains, it is crucial you don't break it all the way by pushing the pin til it falls out. it will lead to extra work when you're trying to push it back in-- a lot harder than pushing it out. just fyi.
  15. yodar
    yodar New Member
    Jul 26, 2010
    147
    At the gas pump 500 yards from home The carb was POURING GAS onto my foot...turned out the throttle cable broke when i stopped and there was NO WAY to pull it off full throttle.
    Turned the petcock off, pedaled home and ordered a new throttle cable (2nd one to brake in the same place right above the lead ball in 3 months)
    yodar
  16. killercanuck
    Dec 17, 2009
    1,749
