Cant Post pics from ipad
Discussion in 'Motorized Bicycle General Discussion' started by "the prussian" Shop Dogs, Feb 19, 2011.
  1. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    Anyone else have this issue? Am new to apple software so maybe doing something wrong . So does the forum accept image files from apple?
    Any wisdom greatly appericated
  2. give me vtec
    give me vtec New Member
    Jun 19, 2009
    167
    nope, I can't figure it out either. I've even tried photo bucket.
  3. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Can you import your photos to a photo program like Photo Shop or Photo Pro? If so, import then save as a jpeg file. I believe even MS paint will let you save them to jpeg.
  4. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    Apple is still a little weird to me as im used to ms os systems ,the problem seems to be some thing apple has put in place . No matter were i try and import them from the forum tool for attch. Won't select any pics ? When you hit manage button no files from own computer show ,cant even search thru them nada...
  5. Tacomancini
    Tacomancini Member
    Mar 18, 2010
    163
    There has to be a quicker way than this, but this seems like it would work, as you can attach an image from a web url. Dropbox is free, and allows you to put images in it to share. The trick seems to be shrinking it down for the file size limitation. This guy below uses image shack for the resize. Maybe there is another free service (instagram maybe?) that could get you a web friendly size at a public url.
    This ipad app is 3 bucks and resizes as well as shares it to dropbox: OneEdit for iPad - Batch Image Edit, Transfer & Upload for iPad on the iTunes App Store
    Here's the free way though -
    Intructions from whpalmer4: iPad: how to attach photo to msg? - The Omni Group Forums
    Install the Dropbox app, if you haven't already done so.
    Launch Dropbox, and navigate to the Public folder. Now tap the + at bottom left, and choose Existing Photo or Video. This will launch the photo picker and allow you to select an image which has been saved in your photo library. Once you've done that, the image will be uploaded to your Dropbox account and can be shared or published.
    With the photo you just uploaded selected in the Dropbox sidebar (you should see the image on the right), tap the little chain link button in the menu bar, and choose Copy Link to Clipboard. Because you uploaded the image to your Public folder, this will give you a link that you can publish so anyone can see that image file.
    Now leave Dropbox and launch Safari. Go to ImageShack® - Online Photo and Video Hosting and tap the "url" button next to Upload. Then click in the "Paste image url here" field and paste in the URL that you generated earlier. Now make any changes you want to the image size, label, etc. and upload. When it is done, you'll get a list of links to share your image. I typically use the Forum Code choice. Tap in the field, tap Select All, then tap Copy (which will show up off to the right). Now you can go back to the page where you are editing your post and paste in the contents of the clipboard to insert the image on the spot.
  6. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    WOW well i ask for it ,thanks for the advice ,your right there has to be a easer way but ill give it a shot. Three bucks aint much for bragging rights.
  7. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    Well dropbow will let me paste a link to image ,but the are invalid?
    When i try and paste image there is nothing there?
    This is gettin frustrating but ill stick with it.
  8. Tacomancini
    Tacomancini Member
    Mar 18, 2010
    163
    lemme know if you figure it out.
  9. "the prussian" Shop Dogs
    Jul 15, 2009
    620
    "victory is mine!" at long last
    http://db.tt/PlCGt3Y
    Long story short ,ipad files in html5 wont show up on any flash viewer, thats why the forum software did'nt allow you to select anything.
    The fix came by loading pics thru dropbox mobile , that seems to have a patch or converter. Then the links from dropbox actualy link to pic vs invalid link.
    So at least link to dropbox works ,it's better then nothing.
  10. Nougat
    Nougat New Member
    Nov 4, 2009
    1,332
    I know that my iPhone, when plugged into my Windows computer, shows up as a mobile device drive that I can browse, and pull pictures and videos from. That's how I get pictures off my phone. Since the iPad is essentially the same OS, it ought to be the same.
