Can I get going with out pedaling?
Discussion in 'Motorized Bicycle General Discussion' started by greekfreak, Mar 30, 2010.
  1. greekfreak
    greekfreak New Member
    Mar 20, 2010
    6
    I have the 80cc kit on my motorbike using a 36t sprocket and the newer style clutch lever, I want to know if there is something I need to get the bike going without having to pedal everytime im at a stop. Any help would be appreciated :)
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    Sure- a SBP shift kit would be perfect for you.
  3. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    A Centrifugal Clutch (automatic) if your looking for a bolt on and go.
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    Or that.
    How about a link for the guy? ;)
  5. greekfreak
    Mar 20, 2010
    6
    Link for the clutch would be greatly appreciated :)
  6. Creative Engineering
    Sep 20, 2008
    1,668
    Greek,
    With a 36T rear sprocket and a stock engine...you will need to pedal a bit before you engage the engine.
    Jim
  7. greekfreak
    Mar 20, 2010
    6
    So it wouldnt be worth buying the centrifugal clutch? Wouldnt I just be able to ride the clutch a little longer to get it going? or would that eat the clutch up quick?
  8. Bikeguy Joe
    Jan 8, 2008
    11,529
    It will definitely reduce the clutch pads' life....a lot.
  9. Allen_Wrench
    Feb 6, 2010
    2,787
    I guarantee that if I had ever taken the centrifugal clutch off my old moped, I'd just have to pedal. Or get a good gearbox. Up there ↑ is your answer: shift kit, centrifugal clutch, or twiddle your toes.
    *Hey everybody, I know Sick Bike Parts have the best jack shafts and shift kits, but for the centrifugal clutch - would that be That's Dax's turf. I think I saw 'em there. Help me out.
    PS - I just saw the latest. Never mind, if you got a 36T, you may very well be needing a shift kit.
    #9 Allen_Wrench, Mar 30, 2010
  10. greekfreak
    Mar 20, 2010
    6
    nope thatsdax doesnt carry the clutch. I guess I might just have to stick to peddling for now.
  11. Creative Engineering
    Sep 20, 2008
    1,668
    You can get away with momentary 2-3 second clutch actions without a problem. If you slip the clutch for a prolonged time the pads will rapidly wear out. With a 36T, from a dead stop, you are looking at prolonged clutch feathering in order to get going with a 36T sprocket.
    Jim
    #11 Creative Engineering, Mar 30, 2010
  12. AaronF
    AaronF New Member
    Aug 24, 2009
    389
  13. jviperm
    jviperm New Member
    Oct 3, 2009
    13
    Gasbike.net has them I just got mine from them today.
    Click on their add in left column
  14. AaronF
    AaronF New Member
    Aug 24, 2009
    389
  15. pdubs
    pdubs New Member
    Jan 16, 2010
    74
    keep in mind that when using a pull start and/or centrifugal clutch you will need offset crank arms or an extended spindle. i just put a pullstart on my jackshaft bike, works great. oh, and i slow roll stop signs using the clutch without pedaling :D
    but even at a dead stop i pedal to get it going.. if you ever drove anything with a clutch you can tell how long you can slip it out.
  16. AaronF
    AaronF New Member
    Aug 24, 2009
    389
    Great info! I've been searching for some cheap short crank arms but nothing.Could you recommend somewhere for square taper arms?
  17. foureasy
    foureasy New Member
    Jul 9, 2009
    478
    boygofast for the centrifugal clutch. 25 bucks to your door
  18. the new ausped
    the new ausped New Member
    Feb 10, 2010
    144
    whats wrong with a bit of peddling? look on the bright side at least you dont have to pedal every ware...
    maybee if you, leant way over the handlebars peaked the rpms and dropped the clutch it might work
  19. the new ausped
    Feb 10, 2010
    144
    !! but that is how i get my bike going everyday... no wonder all my sh!t doesnt work :/ dnut
  20. HseLoMein
    HseLoMein New Member
    Oct 30, 2008
    121
    you can always get off the bike, disengage the clutch, run with said bike and when you feel you are moving fast enough, jump on the bike, get situated, dump the clutch and take off
    or
    you can sit on the bike and walk it while sitting down, its a funny looking manuver but my buddy does it all the time, he took off his pedal chain. some of the guys who were at the CT rally last year, called it that wadling duck maneuver.
