can a rear V-BRAKE be mouted easily?
Discussion in 'Motorized Cruiser Bicycles' started by Bryman31, Jun 16, 2010.
  1. Bryman31
    Bryman31 New Member
    May 6, 2010
    24
    so this bike here is the spookytooth stealth, i want it cause of its flat blackness. BUT it has no rear v-brake only a rear coaster brake. would it be possible to add a rear v-brake and do away with the coaster brake? or is this just dumb?
  2. CoastalCruiser
    CoastalCruiser New Member
    Apr 28, 2010
    338
    It's just dumb.
  3. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    If its a steel bike (I'm believing it's the first one of the two pic's),then I'm seeing the tube cut from a donor bike w/brk lugs attatched on top of the bottom chain stay.,leaving the clean upper coaster look on the top tube
  4. Millsy
    Millsy New Member
    May 16, 2010
    25
    Anything can be done its just how much work you want to do:-||
    I have done this sort of thing on some of my bikes got to get it right or it wont work.
  5. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Yes,That covers most mechanical tilngs,You'll have a better chance starting with a operable part if you want success
  6. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    If the fork has a hole already in it"right above the tire" then you can add a $10 side pull caliper very easy or if you want the other $$ style brakes you can get a $10 adapter plate that comes with 2 lugs.
  7. CoastalCruiser
    Apr 28, 2010
    338
  8. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Good find CC I think I will do it too
  9. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
