Busted chain
Discussion in 'Motorized Bicycle General Discussion' started by subsailortrainman, Jul 3, 2012.
  1. subsailortrainman
    subsailortrainman New Member
    Jun 26, 2012
    Hey Guys!
    I am a newb who just finished my build, and I got the engine to start, went 20 feet and the chain broke????? It appeared to have derailed, and then got caught in the sprocket nuts, and broke into several pieces.
    So.... Did I have the chain too loose, too tight or just right and it screwed up anyway??
    It appears the tire is a bit too wide, and the chain is rubbing on the rear tire.
    I bought a 1.75" tire to replace the 2.25" tire.
    Any advice will be appreciated!!!
    Thanks!!
    Dave:-||
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    http://www.google.com/cse?cx=partne...16#gsc.tab=0&gsc.q=Chain alignment&gsc.page=1
    Here's some reading for you.
    Proper chain alignment and tension are critical. The drive and driven sprockets (engine and rear wheel) must be in an absolutely straight line. The tensioner wheel must also align with the chain path. The rear, driven sprocket, must be centered on the rear wheel hub. Any misalignment or out of concentricity will cause you problems.
    Roller chains will perform perfectly if properly aligned and tensioned.
    The kit supplied chain has a bad reputation but even it will serve you well if properly installed.
  3. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    If the chain was rubbing the tire, why did you ride it?
  4. subsailortrainman
    Jun 26, 2012
    Thanks! I will double check the alignment when I get the new chain.
    I rode it because it was lightly rubbing on the tire, not being deflected by it.
    I will try a thinner tire when the new chain comes.
  5. Mike B
    Mike B New Member
    Mar 23, 2011
    2,256
    That's what I did, got a thinner tire.
    Never ride a bike that has a chain rub anywhere, it's dangerous.
