Burned Oil in Muffler??
Discussion in 'Motorized Bicycle General Discussion' started by Kevron99, Apr 29, 2010.
  1. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    What could be the cause of having a burnt (thick black) oil under the end tip of the muffler? I have been searching and looking for possible cause but cant seem to find it? I am baffled...Any suggestion?
    See pics. Oild where the red arrow..
      File size:
      87.7 KB
      121
  2. Venice Motor Bikes
    Mar 20, 2008
    6,174
    Unburnt oil blows out the end of the pipe... thats just a burnt drip. totally normal.
  3. 2door
    2door Moderator
    Staff Member
    16,304
    29
    What fuel mix ratio are you running? All 2 stroke engines will expell oil as the oil is not actually burned but used only as lubrication. It has to go somehwere. The higher the oil content, the more oil you can expect to see at the exhaust.
  4. flybytaco
    flybytaco Metal Molding Madman
    Oct 17, 2009
    1,176
    yea lol it's normal when people run theese crazy mixtures
  5. Venice Motor Bikes
    Mar 20, 2008
    6,174
    There's also unburnt fuel that goes out the pipe too!
  6. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    Tom,
    I am using opti 2 100:1 mix. The 1.8oz to a gallon. Its running very good with this oil and no smoke...but just wondering where the oil comes from...
    Thanks also Venice.
  7. 2door
    2door Moderator
    Staff Member
    16,304
    29
    Kev, That's unusual for the Opti-2.
    I too run Opti @ 100:1 and do not have the problem. In fact there is little to no oil residue from the mufflers of any of my bikes. I'm wondering of that muffler you're using has anything to do with it but I don't see why it should. As long as your engine is running good and the spark plug reading is saying things are okay, I wouldn't worry too much about it.
  8. Kevron99
    Kevron99 New Member
    Aug 11, 2009
    261
    My plugs looks OK at very light brown in color. I think it only happens when I use the headlight as it runs via the white wire,...could it be the cause robbing power therefore the plugs not efficiently burning the fuel?
  9. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,433
    I say better an oily mixture than a blown engine- unless the plug fouls up- I have this condition now with a poo poo pipe that I can't yet ream- I didn't notice it when I drilled an extra hole or two in the back plate of the muffler-
    I didn't like the end cap having a smaller opening than the exhaust manifold- and I never noticed oil before with standard yet drilled exhaust-
    the downside?- I lost the end cap when it came off! If you drill it, make sure it's tight then- and it's probably just a shade louder
    PS- this billet intake works great! I still haven't yet put the NTS 66 carb on, it's running so well with the old stock carb- about $15 from creative engineering and Pirates.
    #9 Nashville Kat, Apr 29, 2010
  10. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
    BTW, the reason for that even with a proper tuned exhaust is a certain amount of exhaust backpressure is needed with a 2 stroke to prevent unburned fuel/air mixture passing right through the cylinder & into the exhaust.
    I suspect Kevron's deposits are prolly normal however *shrug*
  11. Cabinfever1977
    Cabinfever1977 New Member
    Mar 23, 2009
    2,290
    Oil goes in, oil comes out. But even with my cheap $3 2-stroke oil, i never have any smoke come out,not even in winter. sometimes i have a litle oil residue on the end of my muffler and under bike frame, but a little wipe after it cools off and no problems.
