Building an engine
Discussion in 'Motorized Bicycle General Discussion' started by aparra619, Sep 20, 2013.
  1. aparra619
    aparra619 New Member
    Sep 20, 2013
    Hi I am new to this and i have not been able to find a forum to help me put a top end and bottom end together. its a 2 stroke engine and bot parts are new.
    Thanks
    Alex
  2. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,077
    Yes,well that's nice, but what kind of a 2 stroke? We are glad to help,but help to you , you need to give us more to work with.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Welcome to the forum.
    Is this a Chinese 2 stroke bicycle engine? Where did you buy it? Was it disassembled when you got it? Some suppliers are now selling engines in parts to get passed current EPA import regulations. I assume this is what you have but we do need more information.
    Assembly isn't difficult but you need a certain degree of basic engine knowledge to do it right.
    Get back to us with some particulars and we can offer more assistance.
  4. aparra619
    Sep 20, 2013
    I am not to sure if you are familiar with DAX Motors. I bought the top and bottom end of an F80 2 stroke type D gen IV. if you go towards the bottom of this page http://www.thatsdax.com/ENGINE_KIT_PARTS_PAGE_3.html you will see the motor.
    And yes it is for a bicycle. I have some knowledge on how to build it. For instance, i know the piston clips/rings should be at a 12 o'clock or 6 o'clock position and to use a lot of syn 2 stroke oil in the cylinder and put some in the bottom end.
  5. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,442
    6
    The one major difference to know is- I believe- whether the engine block (jug) studs are 6 mm or 8mm.
    I believe- and there may be exceptions I'm not aware of- almost all top ends will fit the 6 mm stud bottom, except those specifically 8mm
    6mm is an older standard, and while 66 motors and top ends still come in 6mm,
    there's a gradual change to 8mm in 66 cc motors.
    That's part of this game- some suppliers and their stocks may be YEARS behind trends otherwise. 8 mm studs in 66 motors began a few years back and has become more common I'm sure, but if you have a concern or preference you really have to ask a vendor.
    It's getting harder these days to come by either 6mm stud bottoms and 50 cc parts, though they are as of now still generally available, their share of the market decreases
    Too bad I think- after almost 5 years, I sorta prefer a smaller motor- and mostly for the carburetion aspect- they decrease in revs quicker and idle better, even if they aren't as powerful.
    for instance- boygofast was largely selling bottom end with 6 mm studs until very recently- now advertising only 8mm -
    #5 Nashville Kat, Sep 21, 2013
  6. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Well you got an excellent engine there , piston ringsmost line upwith pins in ring grooves that prevents ring rom rotating in grooves, a dab of oil on cylinder on lower bearings is all thats needed.
  7. Huffydavidson
    Jan 29, 2012
    1,077
    I sounds like he's talking about the wrist pin clips. Most of us know them as E-clips.
    and yes my stars always a line .
    LMAOlaff
  8. mapbike
    Mar 14, 2010
    5,380
    After re-reading the post I think you're right, not sure what the 12 o'clock 6 o'clock is for with the wrist pin retainer clips, but it wont hurt anything just the same so that isn't an issue, piston rings placement is though.....
    If I had the time I would make a simple straight forward video of installing a complete top end on a lower from start to torquing the head nuts. Someone with a good video camera needs to make a very clear easy to understand video that will walk a noob one step at a time through a correct top end install so we could send them straight to it and they could even use it as a reference throughout the process.
    When I get my lower that is on order I may try to do one and see of my camera will shoot it good enough to be used as a tutorial.
    Map
    .wee.
  9. Scott.D.Lang
    Scott.D.Lang Member
    Jan 1, 2013
    406
    I only have one question how do you have the gen 4 bottom and top end when dax is not shipping them out till the 23/24th of this month. the dates were told to me by the owner of ThatDax for when hes shipping them.
  10. aparra619
    Sep 20, 2013
    i dont have it yet. It is on it way. Im just trying to figure out some info before i get it.
  11. Scott.D.Lang
    Scott.D.Lang Member
    Jan 1, 2013
    406
    that makes more sence lol. they just started shipping today. not hard to put them together one thing Id sujest is a tq wrench
  12. aparra619
    Sep 20, 2013
    awesome.. that good to know. also, if you have any other suggestions please let me know
    thanks
  13. Scott.D.Lang
    Scott.D.Lang Member
    Jan 1, 2013
    406
    to tell the truth its hard to give advice when I have no idea how much you really know about building motors. I can say there are a few good you tube vids that will show you everything you need to know for the most part. one other thing when you tq down your head do it in a criss cross manner and in 3 stages. first stage should should be 40 in lbs second should be 80 in lbs and third should be 120 in lbs. at least that is the tq I tightin mine down to on my last dax motor.
  14. bill2781
    bill2781 Member
    May 24, 2013
    240
  15. MotorBicycleRacing
    Jul 28, 2010
    5,717
    35
    This guy? :)
    That's Fred, who makes the best head on the market for the China Girls and great performance mods too!
