"bucking bar" fell out of 10 tooth sprocket
Discussion in 'Motorized Bicycle Trouble Shooting' started by 1dave1, Jan 4, 2013.
  1. 1dave1
    1dave1 New Member
    Nov 29, 2012
    36
    Hi all,
    I was rebuilding my bike today and I took of the crank shaft cover to get access to the sprocket on the engine. I think something called the "bucking bar", a small piece of metal that looks just like this...
    http://www.bikeberry.com/engine-kit-parts/clutch/bucking-bar.html
    I cannot push it all the way in, it only goes in about half way.
    Anyone know how to fix???
    Thanks a ton
    Dave
  2. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    If it went all the way inside the hollow transmission shaft the clutch release would not be able to work. It is supposed to stick out.
  3. 1dave1
    1dave1 New Member
    Nov 29, 2012
    36
    interesting. The bike worked perfectly and I don't remember having that thing sticking out loosely. I could be totally wrong. Does the bucking bar just rest in that hole ever so slightly?
    I'm having issues w/ installing the clutch. Should I put that bucking bar into the crank shaft and then install the clutch? Would that explain why the clutch is not working? What confuses me is that I also have a semi stripped clutch lever and chord so I'm not sure why I dont get the same tension on the clutch.
    Thanks for the reply and any help.
  4. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,369
    35
    When you put it in the hole, it should stick out at least a 1/4 inch. Sometimes it will be a bit further out. There is also an 8mm steel ball behind it in that hole that may sometime fall out.
    If you have the clutch off, the spring tension may cause it to stick out further until you get the flower nut to pull a bit on the rod going thru that shaft.
