broken motor mount stud
Discussion in 'Motorized Bicycle General Discussion' started by dakota47l1, Oct 24, 2011.
  1. dakota47l1
    dakota47l1 New Member
    Oct 2, 2011
    132
    had to take my motor to the shop today to have a stud removed...took it to meineke.they removed the broken stud but i lost some threads in the process.he told me to fill the hole about half way up with JB weld and screw in the stud and let it cure....then i could remove the stud.not sure this is going to work.....any thoughts?
  2. dakota47l1
    Oct 2, 2011
    132
    well i guess i'm going to find out.i only got one day of rideing out of this motor.i think the case it toast.have limited tools to work on it.guess i'm going to have to spring for a new case if this doesnt work:(
  3. CTripps
    CTripps Active Member
    Aug 22, 2011
    1,311
    I know JB can do a lot, but I have no experience with it that way. Have you tried a Google search? From what I see at a glance, it's not the best. Among other solutions, Lock-Tite makes a thread repair compound that could be better suited to the task.
  4. Al.Fisherman
    Al.Fisherman New Member
    Sep 9, 2009
    1,966
    JB Weld...don't waste your time.
  5. impression
    impression New Member
    Feb 26, 2009
    244
    Pft Don't do that
    have you got a friend with a tig welder ???
  6. richirich
    richirich New Member
    Aug 16, 2011
    297
    check out the time-sert stripped thread repair kits on amazon. its kinda spendy but it comes with 5 inserts so you could strip out a few more and be covered. ive found it is truly the best way to fix the threads on these motors. and since 6mm is every stud and bolt except for the head( unless you have 6mm head studs too) then this is a valuable tool.
  7. dakota47l1
    Oct 2, 2011
    132
    no i dont:(
  8. dakota47l1
    Oct 2, 2011
    132
    checked it out but its way out of my budget.i could reaplace the whole bottom end for $60.
    also there is not enough supporting material to drill it out any further.the hole is to close to the edge of the case.
    #8 dakota47l1, Oct 26, 2011
  9. dakota47l1
    Oct 2, 2011
    132
    i may just order a new bottom end and have you make me some mounts:)then i will have alot of spare parts
  10. Acraze
    Acraze Member
    May 13, 2011
    231
    I couldn't trust jb either. Seems like it would eventually give.
  11. McCuiball
    McCuiball New Member
    Jan 3, 2011
    15
    If you can still get a stud to ,bite a few turns in it, just use the red lock tite. Worked for me and I have over 800 miles since doing so. You may have to use a shorter stud and re-engineer your mount, but that's the fun easy stuff. Think outside the box (hate that term).
  12. donb4103
    donb4103 Member
    Oct 7, 2011
    167
    I have used JB Weld when I have some of the threads left. It`s useless if completely stripped but it will hold good if you have some threads for it to bond to. I have about 1200 miles on a JB repair job.
  13. Al.Fisherman
    Sep 9, 2009
    1,966
    I have done this on a old head to experiment with. I drilled all the way through into the the cylinder stud hole. . Then I taped as far as I could, stopping short of the cylinder itself. Didn't want the tap to bind. . There is about 1/4" more to be used. Coated the stud with (I use red) lock tite. Install a cylinder bolt where drilled, screw the stud in to the cylinder stud and back off about 1/4 turn, and let sit at least overnight, 24 hrs if you can. I used a drill press and made a jig for the cylinder jug. I've also aluminum welded the hole, drilled, and cut new threads. Works like a champ.
    [​IMG] [​IMG]
    #13 Al.Fisherman, Oct 26, 2011
  14. vincent713
    vincent713 New Member
    Jun 2, 2010
    287
    I had similar issue with my spark plug hole thread got stripped, always be careful when you loosen or tighten spark plug! These cheap threads can easily get stripped. I took it to a local machinist who welded the hole up then drill a hole and tap, problem solved. He also milled out the head and when I installed it, it actually made my engine pull stronger!
  15. alienboy366
    alienboy366 New Member
    Jun 23, 2011
    114
    alrightie, i had the same situation a few weeks ago. if you stripped the motor mounts or similar sizes, dont drill it out, if you haven't damaged it too bad, go get a 1/4-20 tap for a few bucks as well as 1/4-20 threaded rod (electrical section- 5 dolars for like 5 feet). carefully tap it and use some red or blue loc tite.
