boosting compression? ideas?
Discussion in 'Motorized Bicycle General Discussion' started by Thunderhead289, Oct 30, 2013.
  1. Thunderhead289
    Thunderhead289 New Member
    Jul 2, 2013
    49
    so I shaved my head down a bit and was curious on everyones opinion on doing so.
    I also drilled a few extra holes in the baffling of the exhaust due to the higher compression.
    can anyone tell me the adverse effects of lessoning the back pressure. what negative effects will it have? obviously with less back pressure there will be more heat in the chamber, but is there anything more than that?
    bear with the video a bit as I made it to get views on youtube since I get paid through ads.
    https://www.youtube.com/watch?v=ZMMbWtStkTY
  2. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    Get an expansion pipe, less back pressure where it's unneeded, back pressure where it is needed.
  3. Thunderhead289
    Jul 2, 2013
    49
    explain that too me, where is the back pressure needed?
    I cant bring myself to get one over a shift kit, I just do not care for the look of them even if they are such an improvement. id love to build a motor for best power, though I seriously doubt the bottom end integrity of these motors.
    #3 Thunderhead289, Oct 30, 2013
  4. Nashville Kat
    Nashville Kat Active Member
    Apr 20, 2009
    1,433
    I file the head down flat- I take all the ridge away that fits down onto the head gasket-
    the normal ridge actually makes the head gasket have a smaller area of contact, and usually bends the head gasket onto two different planes
    anyway, filing that ridge away takes a little bit of top cylinder space away, and with the same bore and stroke otherwise, increases compression- I could really feel the pop when I first did it
    the head gasket is not compromised either in volume or squashed into two different planes, so in theory and probability at least, it should last longer and seal better.
    I just got an odd extra 50 cc engine dirt cheap on ebay- the straight verticle plug head is ALREADY flat with no ridge- so I'm curious as to when it could have been made, and have no way to find out.
    #4 Nashville Kat, Oct 31, 2013
  5. mapbike
    mapbike Active Member
    Mar 14, 2010
    5,380
    Actually the bottom of these engines does pretty good, the wrist pin/upper bearing is normally the weak spot on these engines when bearing fails its usually that one, sanding the head down flush wont hurt a thing, I've done it multiple times, it will increase compression and give your engine a bit more grunt power and help power even on top end, a well tuned carb and a free flowing exhaust is where to biggest improvement is on a basically stock engine, I will include links to upper bearing which is very good quality.
    http://www.pocketbikeparts.com/Piston_Wrist_Pin_Bearing_p/cgpr302450.htm
    https://www.treatland.tv/malossi-needle-bearing-p/malossi-needle-bearing-663209b.htm
    Map
    #5 mapbike, Oct 31, 2013
  6. Thunderhead289
    Jul 2, 2013
    49
    so if I run it richer to keep the combustion temps down I should be alright with less back pressure? im sure it will use more fuel due to better flow, but im not all too worried about fuel mileage with what these get!
  7. dodge dude94
    Jun 8, 2012
    1,017
    You'll need to jet it richer because more air in/out means you'll need more fuel.
    Simple engine dynamics.
  8. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,075
    So, what saying is, that if I shoot some holes in the can I'll have higher compression ?
    Dang , after all the money and machine work I've done and spent , NOW you tell me.
    LMAO
