bogggggggggggging!!!!!!
Discussion in 'Motorized Bicycle General Discussion' started by hcrft, Aug 26, 2013.
  1. hcrft
    hcrft New Member
    Jan 4, 2013
    28
    just built my fourth bike. brand new engiine. i used break in fuel mix, and was gentle with her for 10 days. took her out for her first real ride yesterday. rode over 60 miles and she ran beautifully. flawlessly. i got up the next day and she ran fine for a minute or two, then couldnt make any power. all she does is bog bogg bogggg. if i open the choke a tiny bit she will limp around. i simly dont understand the difference in performance with out me changing anything. i need help from a carb expert.
  2. Huffydavidson
    Huffydavidson STREETRACER/MANUFACTURER
    Jan 29, 2012
    1,077
    OK, we need more info. What engine are you running, what carb do you have?.
  3. hcrft
    hcrft New Member
    Jan 4, 2013
    28
    im using as grubee sky hawk with thier CNS type performance carbs. i prefer the NT carbs myself because of the simplicity
  4. Huffydavidson
    Jan 29, 2012
    1,077
    I would say check your head that's it torque down correctly , as for as that CNS carb all I can say is good Lucy. I run a sha clone (RT) , I'm not the guy to help with that carb. Theirs some members here that can help you . Good luck.
  5. 60weight
    60weight Member
    Sep 15, 2011
    105
    Check the fuel flow to carb,with a full tank..Your filter may be restricting flow.
  6. dodge dude94
    dodge dude94 New Member
    Jun 8, 2012
    1,017
    New build? What mix ratio are you running?
    I'd be checking the fuel line as suggested above and pull the bowl.
