Bike wont start
Discussion in 'Motorized Bicycle Trouble Shooting' started by graydog8josh, Mar 9, 2013.
  1. graydog8josh
    graydog8josh New Member
    Nov 23, 2012
    447
    my bike wont start. I have a 66cc ported and reeded. nt carb rebuilt, stripped head bolt, helicoiled. I checked and i have spark. i poured gas in the plug hole and was able to get the engine to fire. but i cant get it to run. what do i try next.
  2. bwader
    bwader New Member
    Feb 10, 2013
    21
    I had that problem on my first engine. I long considered buying a new bottom end engine. But for $90 I bought a brand new 2 stroke from LEB on ebay and it started right up!
    You could try buying a new bottom end and replace it for cheaper.
    I think it depends on availablity of parts for you and how much you can spend.
  3. bwader
    bwader New Member
    Feb 10, 2013
    21
    66cc engines are a little cheaper than 49cc's off luckyearlybird
  4. UVsaturated
    UVsaturated New Member
    May 15, 2008
    140
    You obviously aren't getting enough fuel. I would look for vacuum leaks and fuel bowl not being filled (needle and seat stuck, fuel filter clogged, float level set incorrectly)
  5. 2door
    2door Moderator
    16,285
    Did it ever run with that carburetor/reed combination?
  6. crassius
    crassius Active Member
    Sep 30, 2012
    3,126
    first thing I'd do (if I had the old carb & manifold around) is put it back to stock & get it running and broken in - then I'd work out any problems when I put the reed back on
