Bike runs good once started, but pedaling is difficult
Discussion in 'Motorized Bicycle General Discussion' started by BOREDTrackRacer, Jan 25, 2010.
  1. BOREDTrackRacer
    BOREDTrackRacer New Member
    Nov 10, 2009
    41
    I've had my bike up and running for a few months now. Its recently developed a problem where when I have the clutch pulled all the way in to pedal, it is very difficult to pedal and also makes a squealing noise. Once I get the bike started its fine.
    I have tried readjusting the clutch, I took off the side cover and looked at the flower nut and loosened that, didn't help. What else could it be? Thanks in advance
  2. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Sounds like cable stretch to me. The clutch cable can, over time stretch requiring readjustment of the cable tension at the engine clutch lever. You'll want to shoot for about an 1/8" play at the lever, no more than that. The cable should be snug but not tight. If you've ruled this out get back to us.
    #2 2door, Jan 25, 2010
  3. BOREDTrackRacer
    Nov 10, 2009
    41
    I have adjusted the clutch cable numerous times to no avail..
  4. Norman
    Norman LORD VADER Moderator
    Staff Member
    Jan 16, 2008
    2,605
    have you greased the short clutch rod and the ball bearing behind it ?
  5. bairdco
    Aug 18, 2009
    6,350
    25
    have you tried lifting the bike up and spinning the wheel with the clutch engaged? could be damaged bearings, cones too tight, or a messed up coaster brake.
