Bike frame Mod
Discussion in 'Motorized Bicycle General Discussion' started by air250, Sep 28, 2011.
Tags:
  1. air250
    air250 New Member
    Sep 23, 2011
    23
    Douse any one know if it is ok to cut off the sunspot beam from the Tim Hornets bicycle i have it circled in yellow in the pic attachment. is it just for looks or its is support as well.
  2. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Do not remove those parts. They are structural members called cantilever tubes and removing them can seriously compromise the frame's integrity.
  3. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    I wouldn't Air. Seems like it could be the cause of a catastrophic failure.
    Looks like you have enough room for almost any of the commonly used engines. Do you need to remove them or just thinking about it?
  4. inked1974
    inked1974 Member
    Apr 11, 2011
    278
  5. air250
    air250 New Member
    Sep 23, 2011
    23
    Ok thanks all for the reply's i will take it into consideration I'm probably going to just leave them and work around it
  6. inked1974
    inked1974 Member
    Apr 11, 2011
    278
    Kind of an after thought but I will say that I have only modified the cantilever tubes purely for the "look" I was trying to achieve at that time. I do have trust in my Tig ability but I DO certainly inspect the prone to fail areas often.
  7. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    Did you just not like the looks of them Air? Or was there a need for the added room?
    Just wondering. Most every problem has been solved or met with some sort of compromise to get the end result you want or need.
    Just a personal preference, but that is a good looking cruiser and gonna make a great MB.
  8. air250
    air250 New Member
    Sep 23, 2011
    23
    its more for room i have a 3.5 B&S vertical shaft that i converted to a Horizontal shaft and the conversion made it kind of bulky (and it was not small to start with) so the extra room would b well used
  9. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    OH man! How did you convert to horizontal?
    I have been working on this for a couple of years using worm gears. I have yet to try the just turning the carb but gonna have to try it I guess.
    Very cool and glad I asked.
  10. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Vertical to horizontal? I hope you've thought about the crankcase/oil issue. :)
  11. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    You could do it with belts, kinda like how those old Hoover upright vacuums that has the belt in the front that crosses like an 'X' and powers the beater brushes.
    [​IMG]
  12. air250
    air250 New Member
    Sep 23, 2011
    23
  13. air250
    air250 New Member
    Sep 23, 2011
    23
    wont the belts burn out if you have it direct to the shaft like that
