Big jugs
Discussion in 'Heads and Cylinders' started by Mouse, Jan 28, 2016.
  1. Mouse
    Mouse New Member
    Jan 1, 2016
    13
    I have a 48cc grubee Skyhawk 2 stroke can I change the jug and piston to a 66/80cc?†
  2. ckangaroo70
    ckangaroo70 Active Member
    May 13, 2011
    818
    53
    Large jugs? Sorry...was expecting to see something different here. lol
    Really don't know why you couldn't go with the larger displacement jug. I think the lower ends are basicly the same on most all the china girls and I would assume the cranks the same, but perhaps more research is in order
  3. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,943
    91
    The stud spacing is not the same, I don't have the specs but I do know my 48cc's and the one 66cc are different.
  4. Mouse
    Mouse New Member
    Jan 1, 2016
    13
    Is there any one who could help me with finding a faster reliable motor ? I'd like to go35-45mph without going wide open on the throttle. And can I modify the existing motor to do that?
  5. Greg58
    May 1, 2011
    2,943
    91
    There are a lot of modifications that will increase speed, porting done right is one. Adding a expansion chamber is another, changing rear sprockets from a stock 44t to something with less teeth will increase top speed but cuts hill climbing ability. If you do upgrades do one thing at a time, that way you'll know if what you did helped or hurt performance.
  6. Mouse
    Mouse New Member
    Jan 1, 2016
    13
    What about a jackshaft and hooking it into the existing bike gears?
  7. Greg58
    May 1, 2011
    2,943
    91
    Yes a jackshaft kit will help, here in Georgia a multi-speed moped is not legal so you might want to check your state laws.
  8. Chaz
    Chaz Active Member
    Jun 3, 2012
    986
    57
    Mouse, getting a bike to do those speeds is not a problem. Doing those speeds safely is the real issue. You are asking for motorcycle performance from a bicycle, so that bike and all of it's components must be up to the task. I'm guessing that about 75% of your budget and efforts should go into building a solid bicycle foundation to bring it up to manufactured moped standards.
  9. Mouse
    Mouse New Member
    Jan 1, 2016
    13
    Got a grinding feel in bike when motor is engaged. Bearing? Time to rebuild?
  10. sbest
    sbest Member
    Nov 3, 2015
    343
    6mm studs at 42mm for the 48cc.
    8mm studs at 45mm for the 66cc.
    Steve
  11. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,888
    114
    grease the bucking bar & check chain run while there
  12. ajanessetrovy4712
    ajanessetrovy4712 New Member
    Dec 18, 2016
    Not trying to answer for Ben or Gary but last year all the Big Dawg races was on a .05 tree in 7.0
  13. Mouse
    Mouse New Member
    Jan 1, 2016
    13
    Sometimes thinking is not enough. The remedy was rebuilding the clutch.trk
  14. Mouse
    Mouse New Member
    Jan 1, 2016
    13
    Really disappointed that Gruber doesn't make motors any more. A Gruber was my first motor and I never had an issue. Since then only problems with every 2 stroke I bought . Now I have a gx120 I want to put on a bike with a torque converter. But I can't find just the torque converter like on the 212 predator kit that will line up with my back sprocket. Any advice on finding one?
  15. Mouse
    Mouse New Member
    Jan 1, 2016
    13
