Big end bearing failure
Discussion in 'Motorized Bicycle General Discussion' started by crazyme, Nov 8, 2012.
  1. crazyme
    crazyme New Member
    Jan 13, 2012
    How common is big end bearing failure on the 66cc engines, and what are the causes?
  2. littletinman
    littletinman New Member
    May 15, 2012
    231
    Sadly pretty common, I've had mine all fail after about 800 miles. They're cheap. Easy to replace though. You can replace them with Japanese bearings and you should be good to go.
  3. mew905
    mew905 New Member
    Sep 24, 2012
    647
    any idea what the size of them is? I want to buy an SKF equivalent. I imagine the japanese bearings havent failed yet? Or even they fail after such a short distance?
  4. moonerdizzle
    moonerdizzle New Member
    Jun 28, 2009
    874
    never heard of a big end bearing failing, wrist pin bearings fail all the time, but the wrist pin bearing is the small end bearing, and the big end bearing can not be replaced, it is some totally odd ball size, plus you have to press the crank apart to do it, if you toast a big end bearing you might as well buy a new crank
