Back Wheel locked up
Discussion in 'Motorized Bicycle General Discussion' started by jb92, Feb 24, 2016.
  1. jb92
    jb92 New Member
    Feb 24, 2016
    8
    When I go to bump the bike the wheel just locks up and skids. Im not sure where to start
  2. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    My first guess is that the chain might be 'bunched up' on the small sprocket underneath the engine cover.
    Remove the cover & report back what you see.
  3. jb92
    jb92 New Member
    Feb 24, 2016
    8
    The chain was on right any other suggestions?
  4. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    When you pull the clutch lever 'in', does the rear wheel spin freely???
  5. jb92
    jb92 New Member
    Feb 24, 2016
    8
    The chain was on right. Any other suggestions?
  6. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    If you're gonna be 'snarky'? You can just wait for someone else to help you... :p
  7. jb92
    jb92 New Member
    Feb 24, 2016
    8
    Yeah. It pedals with the clutch in but it will just lock up and skid when you release it
  8. jb92
    jb92 New Member
    Feb 24, 2016
    8
    Sorry I really dont use forums or articulate well. I really do appreciate the help
  9. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    Ok then...
    Do you have a 'long reach' spark plug in it that might be hitting the top of the piston (& keeping it from turning over)??
  10. Legwon
    Legwon New Member
    Mar 2, 2013
    248
    sounds like either really high compression or something wrong inside the engine itself.
    pull the pull and give it a push with clutch released. if the wheel turns (you should also hear the engine turning over) , replace plug... only finger tight, and try again.
    if the wheel does not turn with plug out, your gonna have to tear it down and find out what is jamming it.
  11. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    That's where I was going next. ;)
  12. jb92
    jb92 New Member
    Feb 24, 2016
    8
    No luck with the spark plug. Im guessing the motor just seized. It was running great, I stopped and when I went to go start it again it was locked up
  13. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    Take off all of the side covers & see if you see anything that doesn't look right.
  14. Venice Motor Bikes
    Mar 20, 2008
    6,213
    24
    The next step after that is to remove the head & look inside the cylinder for any damage to the cylinder walls & piston.
  15. jb92
    jb92 New Member
    Feb 24, 2016
    8
    Alright, thank you for your help. I wil let you know what I find
  16. 2door
    2door Moderator
    Staff Member
    16,308
    30
    How fast are you pedaling before you release (engage) the clutch? You need to pedal up to about 10MPH before engaging the clutch. Anything below that and you might have the problem you're having.
  17. jb92
    jb92 New Member
    Feb 24, 2016
    8
    It ended up that the piston was stuck in the head and one of the chambers had broken. I took the motor off the bike and im trying to split the cases so I can clean all of the debris out of the bottom end. I ran into a problem trying to get the front sprocket off. Even when I hold the crank in place the nut wont budge. All i have are sockets and I was wondering if there was quick and easy way to get it off
  18. crassius
    crassius Well-Known Member
    Sep 30, 2012
    3,719
    81
    wrap a small piece of drive chain around it with a "V" in the chain to lock it against the case
