back tire on cruiser to big!
Discussion in 'Motorized Cruiser Bicycles' started by rex-holes, Oct 5, 2011.
  1. rex-holes
    rex-holes New Member
    Oct 5, 2011
    hey guys, i'm new to the motorized bicycles and am trying to build a first time cruizer. not building from scratch and bought a BGF 80cc engine. i started installing but it looks like my rear tire is to wide and will get some chain rub. just wondering if anyone has any ideas on how to fix this or opinions on building my own offset mount for it. thanks for any input in advance:-||:-||
  2. wayne z
    wayne z New Member
    Dec 5, 2010
    1,746
    I built several cruisers with BGF engines, and had to mount the sprocket dished side out and use 1.95 tires to eliminate chain rub.
    #2 wayne z, Oct 5, 2011
  3. happycheapskate
    happycheapskate New Member
    Nov 26, 2009
    1,990
    Same here. I have a 1.95 on the back and don't like it best, but it works.
    There is a part that mates with the left cone/d-shaped extrusion where the coaster arm fits, that moves the coaster arm out 1/2", for about $10 but I can't find it in stock.
    If someone had a bench vise I could use, I might be able to bend the torque arm a little and re-space & re-dish my wheel for a little more clearance (reverse dish, flat on right side)
    1.95 tires are cheap though, $10 at Nashbar and Niagara Cycle.
  4. donb4103
    donb4103 Member
    Oct 7, 2011
    167
    Sometimes I will use the skinny sprockets and throw on a 410 chain with the sprockets reversed. That will also give you a tiny bit more clearance so you won`t get black stuff on your whitewalls.
  5. donb4103
    donb4103 Member
    Oct 7, 2011
    167
    Spooky Tooth I think sells an adapter for your brake lever. It brings it out far enough to get it out of the way.
    #5 donb4103, Oct 27, 2011
