Awesome gasket material
Discussion in 'Motorized Bicycle General Discussion' started by Jumpa, Oct 27, 2011.
  1. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    I finally found some stuff come to find out my brother makes this stuff at his shop it is for extreme temperatures there is think and not so thick stuff attached are a few pictures of the stuff I'm using now on the exhaust It seems to help cut down on vibration this stuff works great
  2. Mozenrath
    Mozenrath New Member
    Jan 13, 2011
    340
    Mind letting us know what that stuff is made of?
  3. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    Specific Gravity: 1.5
    Shelf Life: Much longer than asbestos sheet
    Temperature Limit: 750°F* (399°C)
    Pressure: 1400 psi (99 BAR) @ 750°F
    Sealability: 0,7 ml/hr
    Chloride Content: 100 ppm max
    Compressibility: 7 – 17% (ASTM F-36A)
    Recovery: 50% (Minimum)
    *Typical values derived from tests performed using 1/16" thick material
    It is very very smooth on one side feels like rigid rubberized cloth -without the elasticity is the only way I can think to describe it. I will try to find out more info.
    It is used to seal in toxic chemicals and hi pressure steam they use it where ever there is joint
    "no not that joint" :) . What temp do these bikes reach? 700° on a bad day?
    #3 Jumpa, Oct 28, 2011
  4. rohmell
    rohmell Active Member
    Jun 2, 2010
    1,533
    Is this gasket material available commercially, or does your brother just make it for his own use?
  5. bandito
    bandito New Member
    May 22, 2009
    783
    Cereal boxes make good gaskets with an exacto knife to cut it out.
  6. Barnfresh
    Barnfresh Member
    Sep 5, 2011
    183
    If it's hi-temp gasket material for industrial application than probably nomex fiber/nitrile like garlock blue gard or palmetto supersheet. Your lucky if you you can get small pieces from your bro because both are expensive and hard to get in small sheets.
  7. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    Barnfresh is correct
    Style 2970
    Super sheat ™ I I
    NBR Compre s s e d S h e e t G a s ke t i n g
  8. Jumpa
    Jumpa New Member
    Aug 12, 2011
    607
    Phone book covers also with the shiny sides , is a favorite of mine
