any thing here built to fail...Part Duex
Discussion in 'Motorized Bicycle General Discussion' started by tvc15, Aug 15, 2010.
  1. tvc15
    tvc15 New Member
    Jun 27, 2010
    89
    OK....
    1) Remade the engine mount, what you can't see is the .125" cold roll steel strip on the back side Thanks for the good advise guys!)
    2) Clutch cable modification
    3) Skateboard wheel chain tensioner
    4) Beefed up Venice brakes with aluminum bracket (mostly cosmetic)
    5) Attached tank to a sculpted cedar block fastened to the top tube with brass brackets and a S-load of gorilla glue to secure- feels rock solid
    What is going to fail?
    .duh.
    #1 tvc15, Aug 15, 2010
  2. tvc15
    tvc15 New Member
    Jun 27, 2010
    89
    Some more images
  3. Ursus
    Ursus New Member
    Aug 12, 2010
    45
    looks solid except for the clutch cable modification . NICE WORK!!
  4. tvc15
    tvc15 New Member
    Jun 27, 2010
    89
    Could you expand on that a bit brother? Is it the slack or the material?
  5. scotto-
    Jun 3, 2010
    6,530
    6
    The only thing left to fail is the engine, but you already knew that.
    Well just in case it doesn't, eventually everything fails, just give it time and be prepared. Pretty much everything that breaks can be fixed, unless it just wears out.
    The way I deal with failure is optimistically, it just works better that way. Just remember.....things could ALWAYS be worse, no matter how bad they are. Think positive!
    #5 scotto-, Aug 15, 2010
  6. killercanuck
    killercanuck New Member
    Dec 17, 2009
    1,749
    Sweet looking ride man! Am I the only one worried about the angle of the carb/float bowl? But hey, if it runs, it runs, eh? Nice clutch mod, I'd keep an eye on it in case it starts to warp, and don't leave clutch pulled in when not riding too.
  7. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    That has got to be once of the nicest motor mounts I've ever seen! Well done!
  8. Mac
    Mac New Member
    Dec 3, 2009
    489
    Good job, that setup should prove to be very dependable! Great job.
    Mac
  9. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    On second look I think Ursus may be talking about the way you have the cable mounted to the pivot. There's a lot of stress on the clutch cable and I think the cable mounting tab could use a gusset across the back because I could just see it snapping off.
    And when you get that done make me one! :D
  10. tvc15
    tvc15 New Member
    Jun 27, 2010
    89
    Better, steel brace at bottom not shown... you were right these puppies are under enormous stress, who would have guessed!:-||
  11. scotto-
    Jun 3, 2010
    6,530
    6
    Nice....solved that little problem, that's how they should come from the factory!!!dance1
    Is that an old Yamaha mini-enduro tank and is the rear tire a continental?
    #11 scotto-, Aug 16, 2010
  12. tvc15
    tvc15 New Member
    Jun 27, 2010
    89
    Why yes it is a Yamaha tank but the tire is a Serfas Drifter
  13. azbill
    azbill Active Member
    May 18, 2008
    3,367
    let us know how the drifters perform (wear/ride/etc...) please :)
    I have been thinking of switching to them ;)
    (I wore out my armadillo crossroads (6000 miles) and don't like the stock whitewalls my stretch came with)
  14. scotto-
    Jun 3, 2010
    6,530
    6
    That Serfas is a good looking tire, thanks! And please do let us know of it's performance and longivity, if you will.
