Another Newbie, advice welcome.
Discussion in 'Motorized Cruiser Bicycles' started by bass4life, Sep 28, 2011.
  1. bass4life
    bass4life New Member
    Sep 23, 2011
    Hey guys, I just built a Trek Classic / Boy Go Fast 66cc bike and I'm having the usual problems. The chain tensioner dove into my wheel on the first run (luckily under pedal power and no real damage to the wheel) and the rag joint is giving me fits. I'm fabbing a new tensioner that will actually work and thinking of a hub adapter. I'll post picks when I have time to figure out how (I'm new at the forum thing too). The sprocket that came with the kit is garbage. The hole pattern isn't centered in the sprocket and there's just no way to get this thing to run true.
    Here's my questions. I like the Manic Mechanic adapter and sprocket but I have no idea how to tell wich chain I ended up getting with my kit. The Manic sprockets are listed as only working with a 215 chain. I need to know what chain I actually have and I understand I can not necessarily go by what the kit description says as the pieces / parts tend to vary from kit to kit.
    I'm going to be fabbing the tensioner this weekend and I'll try to get some pics up of that as well. If it works the way I think it will, it's going to be cool. Thanks guys, you've already been a huge help.
  2. zachary
    zachary New Member
    Sep 16, 2011
    43
    you can always bring the chain to a bike shop and they will tell you wat size it is. i think the hub adaper is only for coaster brakes so hopefally this helps you out alittle.
  3. MotorBicycleRacing
    Jul 28, 2010
    5,738
    40
    Manic Mechanic sprocket adapters work with 415 chain.
    415 chain is 3/16" between the chain side plates.
    Some of the Chinese chains that come with the kits are slightly
    narrower than 3/16" but if you order the adapter and sprocket
    at the same time you can get the sprocket made to fit.
    MM makes custom sized sprocket adapters that fit hub diameters
    from 0.9" to 1.7" so they work on freewheel hubs as well as coasters.
    I would suggest that you throw your kit chain away and use a
    #41 chain that you can buy from Ace Hardware.
    #3 MotorBicycleRacing, Sep 28, 2011
  4. bass4life
    Sep 23, 2011
    Thanks MBR! That's exactly the info I needed. I was just headed to Ace to see if they have a chain breaker anyway. I live in Michigan and I REALLY want to get all the mechanicals nailed down before I put this thing in the basement for the winter. Once I know everything works the way I want it to, I can spend the winter making it all fit and look exactly the way I want it to. This is going to be fun.
  5. bass4life
    Sep 23, 2011
    Well, my kit did come with a 415 chain, which measures .200 between the side plates. Ace does have a couple different grades of #41 in 10 foot lengths or by the foot. They do not, however, have a chain breaker for sale. Bummer.
  6. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    I'm not sure if MM ever fixed the problem?, but his sprockets used to only work with #41 chains (not 415). Sportsman & Kings sprockets both work with 41 & 415 chains.
  7. bass4life
    Sep 23, 2011
    Thanks VMB. I'm going to get this tensioner sorted out first. Once I know that's working, I'll decide on the hub adapter and sprocket. Since #41 chain is available a block from my house, I will make sure that whatever I buy is compatible with that. The upgrade to a sprocket that will actually run true would be a good time to chuck the China chain anyway.
  8. bass4life
    Sep 23, 2011
    Ok, that image link above is to a fb picture of my bike. I'm going to have to figure out how to actually put pictures in these posts.
  9. bass4life
    Sep 23, 2011
  10. bass4life
    Sep 23, 2011
    Here's the same pic from a photo bucket link. Just trying to get this picture posting thing figured out.
  11. BarelyAWake
    BarelyAWake New Member
    Jul 21, 2009
    7,209
  12. bass4life
    Sep 23, 2011
    I'm trying some pics again with the help of BarelyAWake. This is a test.
    [​IMG][/URL][/IMG]
    Here's a pic of the rough template I made for the new chain tensioner.
  13. bass4life
    Sep 23, 2011
    Sweet. Now that Barely AWake has me all schooled up, here are a couple more pics of my progress. This tensioner was made during the post traumatic stress of a spoke dive so it's a little bit overkill. I don't mind that and it's staying the way it is. I still have to slot this bracket and mount the tensioner wheel. I'm going to use the stocker from the kit. I like the skateboard wheel idea and I'll convert to that when this one wears out. I may have to bend an offset into this bracket to move the wheel mounting point further back (away from the chain) to compensate for a wider "pulley". No big deal.
    [​IMG][/URL][/IMG]
    [​IMG][/URL][/IMG]
    #13 bass4life, Oct 1, 2011
  14. Lance Portnoff
    Lance Portnoff New Member
    Mar 22, 2010
    351
    first rule, if your chainline is off you are not going too far. good luck
  15. bass4life
    Sep 23, 2011
    Thanks Lance. That's actually why I'm doing all this. This whole bracket has side to side adjustability so I can put the pulley where I need it and have reasonable expectation that it will stay there. I still have to slot the pulley mount for tension adjustment but, other than that, it's basically done and almost ready for paint. Here's a pic of it installed. Now I have to get this sprocket buttoned down. The "rag joint" is just not working out well and I'm done messing with it. I'm getting a hub adapter and a sprocket that's actually round (figuratively speaking).
    [​IMG][/URL][/IMG]
  16. syates234
    syates234 New Member
    Jun 14, 2011
    36
    So I have asked around and no answer so hopefully I'll get one here. My motor won't fire. I have replaced the cdi and the spark plug but still no fire does anyone have any suggestions...
