After 200 miles of riding I hit a snag
Discussion in 'Introduce Yourself' started by lanemag, Apr 18, 2010.
  1. lanemag
    lanemag New Member
    Apr 18, 2010
    I recently purchased a raw 66cc bicycle engine kit and have put around 200 miles of use on it. I was riding the other day with my friend and the engine backfired once and the bike slowed to a stop and cut off. I tried to restart it but it was as if the piston was not getting any fire. So I bought a new spark plug and tried it but it still didn't work. I then tried my friends spark plug that we knew was identical to my previous one and it still didn't work. It's hard to explain the problem but when i drop the clutch the engine turns over as long as I pedal but it won't kick on. When I give it gas it sounds like it is trying to get going but can't almost as if its flooding but I checked carburetor and it was fine. Not sure what the problem is can anyone point me in the right direction?
  2. professor
    professor New Member
    Oct 14, 2009
    501
    A back fire occurs on lean mixture. Plugged gas cap vent? Plugged fuel filter?
    Welcome to Motorbicycling!
  3. Alabama Fisherman
    Alabama Fisherman New Member
    Apr 17, 2010
    7
    A backfire can also occur when you have fire (spark) then it cuts out and fires again. I'd also check the magneto CDI and wire and boot.
  4. Bikeguy Joe
    Jan 8, 2008
    11,529
    Check the key on the flywheel.
  5. lanemag
    lanemag New Member
    Apr 18, 2010
    I know that the gas cap and fuel filter are not plugged because I thought the same thing and made sure they weren't. Also, Bikeguy Joe and Alabama Fisherman, could you go into a litter more detail on how I would check and/or fix those problems?
    #5 lanemag, Apr 19, 2010
