About how many miles will a well-maintained 80cc engine last?
Discussion in 'Motorized Bicycle General Discussion' started by alecwhardy, Sep 30, 2012.
  1. alecwhardy
    alecwhardy New Member
    Oct 9, 2011
    21
    With these figures, a cheap chinese engine costing $200 (give or take $50 for additional parts) will pay for itself in a little over a thousand miles.
    $4/ gallon of gas
    120 mpg for the bike
    15 mpg for a car
    On average, how many miles will a well maintained engine last? Im talking about the higher quality ones such as the Dax or the SD Stinger engines? Is something over 1000 miles plausable?
  2. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    yes it is plausible but if you want it to last for years get a 4 stroke of some sort a well maintained 4 stroke will last a lot longer than any 2 stroke kit can
  3. alecwhardy
    Oct 9, 2011
    21
    on average, how long would you say the 2 strokes will last?
  4. The_Aleman
    The_Aleman New Member
    Jul 31, 2008
    2,658
    There's no way to answer that. It's completely variable. That's harder to answer than asking how long a glass of water is gonna take to evaporate!
  5. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    anywhere from a few hundred miles to 10k miles (some replacement parts) depends on your luck with the engine you get and how hard you ride it
  6. Drewd
    Drewd New Member
    Jul 25, 2008
    425
    I've got about 4 years of use on my Dax. I used to re-ring it seach spring but quit doing that 2 years ago. Mine is road hard and put away wet. 25% castor in my blended 2 stroke oil does the trick.
  7. Predator303
    Predator303 New Member
    Apr 26, 2012
    648
    Thats like asking how long will a regular person live.. Anything can happen. Just make sure you wear a helmet because made in China is made in China ;
  8. Allen_Wrench
    Feb 6, 2010
    2,787
    Same engine since 2010. No clue how many miles. Lots. Runs like it was just broken in. Even hauls my 200 lb. + butt up slight hills without me pedaling.
    Now, I did quite a bit of work on it in the beginning: greasing, port matching, tuning, aligning, etc. The less hard they have to work (like anything else) the longer they'll last, I figure. I've heard some on the forum say they had over 10K on theirs.
  9. moonerdizzle
    moonerdizzle New Member
    Jun 28, 2009
    874
    i agree with the castor oil, its better to have too much oil than not enough, you can always clean out the carbon deposits, its a little harder cleaning up piston parts from your muffler. i got about 5000 miles on my 66cc now, reringed it once, and i clean out the carbon and varnish deposits the castor oil leaves twice a year. she still runs good. if you want your motor to last as long as possible, when you get it, tear it apart, clean it out, found casting sand in all the cases ive bought, replace the crank bearings with better quality ones, also replace the wrist pin bearing. Then follow what Allen Wrench said, port matching and what not. but a good quality oil or mix of oils will do wonders, i personally use 4 ounces Mystic JT4 synthetic and 1.5 ounces castor bean oil. a big plus, it is a widly known fact that burning castor bean oil is the smell of manliness and racing.
  10. Venice Motor Bikes
    Mar 20, 2008
    6,228
    32
    These 2-strokes will last for years if maintained properly!
    The very first bike I ever built in 2007 still runs fine.
    My GFs bike is almost 3 years old & still makes it to all the local MB rides. (^)
  11. KCvale
    KCvale Well-Known Member
    Feb 28, 2010
    3,961
    35
    I'm sorry moonerdizzle but I couldn't disagree more.
    Suggesting a rookie break open his new motor case is more likely to leave him with a broken motor before he even tries it than make it better, besides if you buy a good motor like a Skyhawk to begin with all that is already done right to begin with.
    Casting sand in every motor you have bought? What the heck are you buying?
    As for real gas mileage I just figure on 80 MPG because for the most part they are ridden balls to the wall all the time.
    With an expansion chamber maybe 100 because all that wasted fuel that exits the cylinder is forced back in to be burned.
    As for how long the motor will last that is best measured in Hours not Miles like they do heavy equipment, change break-in mix at this may hours, pop the head, inspect the cylinder and re-torque it on at at that many hours, etc.
    I know that is totally unfeasible but if you really wanted to know that would be the way to it.
    Treat it right from the beginning and you can measure it by worn out tire replacements and 2 or 3 times without any major problems is certainly possible.
    As far as how long the motorized bike as whole will last that is as much the bike as it is the motor, I mean come on, it's a bicycle ;-}
    I have no first hand knowledge of this, my personal ride is always something new but one of my very first builds 2 years ago with a Skyhawk rode by a pair of guys almost constantly for a year and half before it was stolen went through 2 sets of tires, 4 plugs, a tailpipe, and some miscellaneous other things like a clutch cable but nothing inside the motor.
