A whole LIST of help needed :(
Discussion in 'Motorized Bicycle General Discussion' started by NerpAngel, Feb 9, 2010.
  1. NerpAngel
    NerpAngel New Member
    Sep 28, 2009
    141
    Actually I made this video today with some questions I have. If you think You can help me on any of them, that would be awesome :) Thanks!
    If you have any questions go ahead and ask away!
    YouTube - Questions about my bike..
  2. Pablo
    Pablo Master Bike Builder & Forum Sponsor
    Dec 28, 2007
    3,652
    Noise normal.
    Clutch arm OK.
    Plug color looks OK.
    Clutch handle must be malformed, contact seller.
    Tighten your plug tighter, it should not come loose.
  3. NerpAngel
    Sep 28, 2009
    141
    so is that what it sounds like breaking in then?
    Oh and problem is.. i got this kit like 4 months ago.. (didn't ride in the winter snow) so.. ya :(
  4. Pablo
    Dec 28, 2007
    3,652
    It will never sound like a Ferrari. Rattly can be normal, until you get an expansion chamber. You could do a clutch cover as well, it will deaden some of the secondary noise.
  5. NerpAngel
    Sep 28, 2009
    141
    I wish it didn't have that annoying high pitch :p
  6. Pablo
    Dec 28, 2007
    3,652
    Maybe I can't hear it over the video..........sounded just about like every other HT engine with the junky stock pipe.
  7. 2door
    2door Moderator
    Staff Member
    16,308
    30
    well that was different. Never had a video presentation of problems but...it does help.
    1. Clutch arm position: There should be a small amount, hardly any, slack in the cable when the clutch is engaged. (handlebar lever not squeezed) The actual position of the clutch arm on the engine is not important. You want it so the cable just starts to move it as you squeeze the lever.
    2. Clutch lever and handlebar:Not sure here. It appears as if the lever doesn't have enough throw to disengage the clutch as it would normally. Without actually feeling the lever and checking clutch engagement and disengagement its hard to identify your problem. Is that the lever that came with your kit? Is there too much slack in the cable?
    3. Spark plug: As I told your earlier. It needs to be torqued to about 10 to 12 foot pounds to seat the gasket and keep it tight. The color looks as if your fuel to air mixture is a little lean. Unusual especially with the 'C' clip on the 2nd notch. These engines typically run rich. You're shooting for a chocolate brown color, not gray or white. That also depends on how much running time on the plug. It might just be that you have not run it enough to get an accurate plug color reading.
    4. Oil: Your choice of oil is fine. if I recall you said you were running a 32:1 mix. That's a little oil lean for initial breakin but not dangerously so. You'll be good.
    Check your clutch cable run for kinks or sharp bends. These will/can cause a hard to pull clutch. It can also mess up the clutch cable's ability to pull the clutch arm in correctly; which could add to that handlebar lever situation. You might try lubricating the cable with light oil or graphite. That often helps reduce the friction.
    Hope some of this helped you. And thanks for the nice vid. Oh, and Pablo is right...sounds normal to me.
    #7 2door, Feb 9, 2010
  8. NerpAngel
    Sep 28, 2009
    141
    Haha well I wasn't going to try and explain my problems because I'm not good at that :)
    Thanks for the help you guys!
  9. The 26incher
    The 26incher New Member
    Dec 19, 2009
    395
    Your video was great bro, love the little captions(ie NKG lol)!
  10. NerpAngel
    Sep 28, 2009
    141
    Btw, I just tightened those 4 bolts on the top of the head. Spun them in bout half a thread with no problem really!! I used about 10 lbs of torque to get em on snug. Maybe that will help with those oil spills at the top?
  11. corgi1
    corgi1 New Member
    Aug 13, 2009
    2,282
    Is the high pitch sound chain wine?,...and is that shadow wearing a helmet?
  12. GearNut
    GearNut Active Member
    Aug 19, 2009
    5,105
    The "secondary" high pitched whine that I heard in the video was the straight cut gears in the transmission. That noise is perfectly normal.
    Straight cut gears are inherently whiny. Have you ever heard a gear driven hot rod engine?
  13. NerpAngel
    Sep 28, 2009
    141
    It will go away with time you think? And that shadow DID ride without one :( I SORRY
  14. GearNut
    Aug 19, 2009
    5,105
    No, it will never go away completely. It's just the nature of straight cut gears.
    It will quiet down some though. The best thing you can do is research the various ways folks here deaden the sound coming through the big teardrop shaped side cover.
    They are all home made solutions. Some use a cardboard insert on the inside, some use rubber inside, some use rubber outside, you will get the picture.
    Oh yeah, about every 100 miles or so, put a pea sized blob of quality grease on the gears, right where they meet. Only a pea sides blob or you will just make a mess of things down the road.
    Actually there is a whole bunch of really simple maintenance things that these motors need to last for thousands of miles.
    http://motorbicycling.com/f30/guide-bicycle-motor-preparation-care-354.html
    I also recommend reading Norm's help section. If only to familiarize yourself with all the quirks and wonders that these little engines have.
  15. leftywoody
    leftywoody New Member
    Aug 23, 2008
    405
    That was a fun vidio and a great technique to use for troubleshooting . Very good idea . I was disappointed also by the whine and just had to get use to it . It looked like your clutch cable was not coming straight out of the hand lever and should be repositioned to have a large looping flow all the way down to the clutch arm . At least in the vidio it looked like is was pinched when it first crosses the handlebars . Just an observation .
  16. NerpAngel
    Sep 28, 2009
    141
    Ya I noticed that too when I took a good look at it! Problem is, this clutch cable is so dang long!!! I have just one big continuous loop down to the clutch arm, but the loop is almost so low it's gonna snag something or get caught in my front wheel..? haha
  17. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Shorten the clutch cable.
  18. NerpAngel
    Sep 28, 2009
    141
    Ya I'm gonna search for forums for that :D
  19. GearNut
    Aug 19, 2009
    5,105
    Cut the outer housing down to an appropriate length for your bike. Just remember to pull the inner wire out enough first so you don't cut both at the same time. It's kinda difficult to re attach the inner cable to the clutch arm when it is exactly the same length as the housing... :)
    P.S. A dremel took works very well. If you don't have one you can also do it with strong, sharp wire cutters and an awl to open up the hole in the end if necessary.
    #19 GearNut, Feb 10, 2010
  20. HoughMade
    HoughMade New Member
    Apr 15, 2008
    624
    Did you clamp the clutch cable under the shifter? Kind of looks like it- I would not do that. That could be causing some of the hard pulling.
