A governor, or speed limiter,
Discussion in 'Motorized Bicycle General Discussion' started by pnz, Sep 10, 2009.
  1. pnz
    pnz New Member
    Aug 19, 2009
    57
    I would like to put a governor, or speed limiter, on my engine does anyone have any good idea's how to make A governor, or speed limiter. Wish it could be a switch. The only other way I could come up with is inside the throttle linkage like a nylon bushing. What is your idea?
    .duh.
    #1 pnz, Sep 10, 2009
  2. silverbear
    silverbear The Boy Who Never Grew Up
    Jul 9, 2009
    8,191
    11
    Hello there,
    I have no idea to help you with. Why not just give it less gas at the throttle? What kind of motor are you using? I'm just curious why you want to go slower. It is kind of refreshing in a way, since almost everybody here wants to go faster. For myself I'm pretty happy going 20-25mph and approaching an incline to goose it to 30 to help make it up to the top without peddling. If I couldn't give it full throttle I wouldn't make it up the hills around here.
    Silverbear
  3. chrisme
    chrisme New Member
    May 30, 2009
    423
    A rev limiter of some sort, either ignition or gas, wouldn't help over-revving due to going down a steep hill. Which is more likely to hurt the engine due to running lean at low throttle. And there isn't really much you can do about it besides be careful to pull in the clutch coasting down hill.
  4. pnz
    pnz New Member
    Aug 19, 2009
    57
    I want to regulate the speed for younger riders. But then maybe they should stay on there big wheels.
  5. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    I'll bet someone could come up with a circuit to interfere with the signal to the CDI at a certain RPM, sort of how rev limiters work on cars. You hit a pre-set RPM and it scrambles the signal to the CDI until your RPMs drop back down below the limit.
  6. chrisme
    chrisme New Member
    May 30, 2009
    423
    Rev limiters on cars are a fuel cut. But yes, you have the right idea.
  7. fall_down_stand_up
    fall_down_stand_up New Member
    Apr 26, 2009
    555
    I thought it had something to do with your signature,There is not a beer that my lips cannot resist hahahaha....Drink much????lol
    John-John
  8. pnz
    pnz New Member
    Aug 19, 2009
    57
    Yes it is, if I am going to fast I may pass a brewery and may not be able to stop.
  9. 2door
    2door Moderator
    Staff Member
    16,308
    30
    That got a giggle from me....thanks. Back to your question; you could adjust your throttle cable so that it would not pull the slide as far. That would be simple but not as convenient as your idea of a switch. Obviously it would require an adjustment whenever the youngsters would ride. Possibly there are some electronic gurus out there who could design such a thing as a rev limiter for a Chinese 2 stroke...but it ain't me. I suppose if I were faced with your problem I'd look at designing a manual device to attach to the twist grip throttle to limit how far it could be twisted. It could be easily attached and removed at your preference. Just my thoughts.
  10. pnz
    pnz New Member
    Aug 19, 2009
    57
    Cheers everyone now off to slumberland along with the swill my braincells are stroming on all kinds of ideas. Remember this stouts for you, or it was till I drank it, sorry.
  11. fall_down_stand_up
    Apr 26, 2009
    555
    If you look at my username,you being a drinker and all,you will understand why I use it....laff
  12. Kevlarr
    Kevlarr New Member
    Jul 22, 2009
    1,628
    Problem with limiting your throttle is you'd lose power everywhere, you'd cripple your low and mid range which you need to climb hills or take off. By limiting the RPM though the CDI signal you'd still have all the power just no top end speed.
    Bet my buddy over at Michigan State could come up with something but that would mean giving up my engine and that ain't happening 'till winter. lol
  13. pnz
    pnz New Member
    Aug 19, 2009
    57
    No, not a drinker I had to stop that, people waiting in the car. I am a guzzler. my signature should say there is no beer safe around these lips aahhhhhhhhhhh.
  14. jimraysr
    jimraysr New Member
    Apr 19, 2008
    78
    My understanding is that they put choke plates in the intake manifold below the carb. in taxies in Chicago in the 30s - 40s. Somebody was saying they would get on a high hill get up as much speed as possible, push in the clutch and let gravity do its thing, then pop the clutch to suck the thin metal plate into the manifold ( and no further ? ). So the suggestion is an intake gasket with a small hole?
    Jim
  15. AslansMonkey
    AslansMonkey Member
    Oct 2, 2008
    195
    Here's an idea...
    Please excuse the crudity of my drawing. It's late and I'm tired...
    Take your throttle apart (just the cover that clamps it to the bar) and you'll see the guide that the cable goes into. Somewhere past where the cable connects drill a hole through the throttle side to side. Then insert a pin through there (use something thick like a piece of wire hanger.
    Locate a spot along the lower housing that you can drill a hole and insert a screw so that when the throttle is rotated, the pin will hit the screw and prevent the throttle from turning further.
    Take the screw out when you wish to drive unlimited.
    Disclaimer...I just thought this up and have NOT tried this myself...though if my 15 year old goes screaming past the cops one more time I might just consider it!
  16. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,641
    62
    That is a cool thought AM. Really, that will work.
    I was going to suggest a big 'ol rear sprocket as a thought. But then you have a slow but great hill climber.
  17. pnz
    pnz New Member
    Aug 19, 2009
    57
    "AslansMonkey Speed Limiter" -Patent Pending-
    Great Idea, You could use a knurled thumbscrew with a e clip on the inside to keep it from vibrating out.
  18. xlite
    xlite New Member
    Jun 18, 2009
    736
    Or simply remove the ring on the cable adjust on top of carb. Slide will now only go part way up.
  19. Flameout
    Flameout New Member
    Oct 23, 2008
    Or put right sized ball bearing on top of slide in carb and put cap back on. That would
    limit the upward motion of the slide.
  20. Outrunner
    Outrunner New Member
    Dec 27, 2008
    147
    The throttle stop screw was common on all of the British bikes from the 50"s
    and into the 70's. There is a adjustable screw and lock nut to limit the amount
    of throttle position at wide open throttle
