A Dark Horse
Discussion in 'Motorized Bicycle Swap And Shop Sales' started by truckd, Aug 17, 2013.
Thread Status:
Not open for further replies.
  1. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    This is a joint build between Dan ( Taylar Motorbikes ) and myself the bike is in between Dan's house and mine during the different facets of the build and fabrication it is a tribute build of a 1911 Indian BTR
    The engine for this bike is a moderately modified PK 69.5/80cc I had sitting around so we decided to use it for this build.
    The bike is going to be a deep Burgundy, Indian never painted their bikes this color however as the bike sat aging ( a 100 YRS. or so ?) in a garage, a basement or old barn, the led in the paint blended with the metal of the bike and turned the color into a Burgundy, most people that find an Indian in it's declining stages often restore the bike using the Burgundy color thinking it was original but not so, no harm no fowl as it doesn't decrease the value of the bike at all and we thought we'd do something different for the color
    Here is a couple pic's of the Frame on stand, Forks & Tank as we start the build, the forks are actually from a 1936 Rollfast and the color is what we're going for.
    #1 truckd, Aug 17, 2013
  2. chainmaker
    chainmaker New Member
    Jan 19, 2010
    2,597
    Signing on for the madness!
  3. Velodrome
    Velodrome New Member
    May 27, 2011
    2,167
    Subscribed! More pictures please!
  4. Allen_Wrench
    Feb 6, 2010
    2,786
    Watchin' this one too.
  5. MotoMagz
    MotoMagz New Member
    Aug 2, 2010
    1,242
    Luv those drop loop frames!
  6. chainmaker
    Jan 19, 2010
    2,597
    Does he make a frame/tank that has a curved top tube or just the angled?
  7. fasteddy
    fasteddy Active Member
    Feb 13, 2009
    5,173
    Yet another build to watch. Life is good.
    Steve.
  8. Venice Motor Bikes
    Mar 20, 2008
    6,142
    This one's looking good! (^)
  9. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Chain.....
    Yes Dan does make a curved back bone frame here is a pic of a curved back bone on a Norton Dan did a while back.
    Here are some build pic's of the engine cylinder porting on the Dark Horse.
  10. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Here are a few more pic's of the porting, fins all cleaned up and intake tube ported as well, I can't tell ya how many tootsie rolls (Drumel sanding rolls)I went through now stay tuned for the paint.
    #10 truckd, Aug 18, 2013
  11. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Sorry Chain here are yer pic's of curved back bone these are the only pic's I have and don't know if they can be sized bigger? I tried and apparently not.
    #11 truckd, Aug 18, 2013
  12. Velodrome
    May 27, 2011
    2,167
  13. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Thanks! Velo sometime the pic's don't come out right from the Iphone
  14. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Engine complete and back together, intake, exchange and exhaust ported out on cylinder, intake manifold tube ported as well as the lower engine casing exchange ports, piston modified and precision needle bearing and machined wrist pin, the head was lapped and lightly polished with sand paper and little 3/16" heat relief drilled in the sides of the head (looks Cool Too)
  15. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Here are some pic of the reassembly and finished product of the moderately modified engine
  16. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    And the final results on the engine, both bottom end gasket and head were hand made with automotive grade gasket material and pro racing aluminum gasket material as well as treated with the copper coating and automotive grade Allen bolts for the head torqued to 12ft lbs, the NT carb was re-jetted and the compression is very good on this little engine.
    #16 truckd, Aug 19, 2013
  17. \./
    \./ New Member
    Dec 4, 2011
    372
    is the mount broke in pic #3 or is it just the angle?
  18. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Yes the edge was broken so we cut that portion off and still have 1" of thread, made a shim for the bolt and it actually helped align the engine very well, the engine was inspected and there is no other damage, could have been bumped during shipping, maybe done at the factory ? I dropped one during paint and the same damage accured still got that one in the closet.
  19. truckd
    truckd New Member
    Oct 19, 2010
    2,746
    Fabrication of the motor mounts and fitting today, we decided to use the squared tubing and then we fab'd an aluminum plate all shined up to go over the top and bent the edges over about a 1/4" to match the faux crank case, the crank case will look like the Redskin's without the dress up and line Ah! well maybe later ? haven't got there yet.
    The crank is a Schwinn Sting Ray 5" as well as the cups and bearings with a Worksman 36 tooth sprocket the wheels are Huffy with 12 gauge spokes that have been re-trued and snugged up a bit the whole wheel will get powder coated Black with cream colored Duro brick pattern 26x2.125" tires, and good Ol' Schwinn tubes.
    #19 truckd, Aug 20, 2013
  20. buba
    buba New Member
    Jul 2, 2010
    913
    truckd
    look'in good
    those kiddie bikes do come in handy for pedal gear etc
Thread Status:
