80cc Clutch Cable Assembly
Discussion in 'Motorized Bicycle General Discussion' started by Wheel Rush, Oct 30, 2012.
  1. Wheel Rush
    Wheel Rush New Member
    Jun 21, 2008
    209
    Hey Motor Bike Heads,
    Winter is coming its time to hit the road, . . . .
    like maybe Florida or California.
    Anyway
    My clutch cable broke at the first eyelet before it goes across to the clutch lever. Would you believe once I am installing the new cable, I am not absolutely positive how it was,(the two springs that go over the cable ), I know I can stick it in there and make it work, but I'd rather see it in a manual. That leaves me with the NTJL Manual - 4, . .
    and that is NO Help! Could you please put me on to a manual for this so I can be sure.
    Stay Cool, . . Mind All the Time !
    #1 Wheel Rush, Oct 30, 2012
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    You don't need either spring. One is a "heat shield" and the other just makes it harder to pull the lever.
  3. 2door
    2door Moderator
    Staff Member
    16,308
    30
    Throw the little one away or in your junk parts box. Like Joe said, it does nothing but make the clutch harder to pull. I always used the heat shield spring when I ran my clutch cables as per the instructions but I make a cable mount that I've used on all later builds that holds the cable away from the cylinder cooling fins so no shield is needed.
    The heat from the engine probably won't melt the cable housing but it certainly can dry out the cable and make it bind or harder to pull.
    Always lubricate the cable before installing it in the housing. Mount it so there are no sharp bends or kinks.
  4. Wheel Rush
    Jun 21, 2008
    209
    Tom ! Joe !
    Got it ;
    Thanks A Lot.
  5. fatdaddy
    fatdaddy New Member
    May 4, 2011
    1,516
    2door is exactly right, throw the little spring in yer junk box. The internal clutch spring will bring the clutch arm back into position. Put the big spring on the cable where it runs against the engine. Put the cable lock snug on the clutch arm cable so there's no slack or play in the cable. You might have to readjust the cable lock after using it for a bit due to cable stretch and cable housing compression. But thats it, Good Luck bro.
    fatdaddy.
