4G-T vs Storm
Discussion in 'Motorized Bicycle General Discussion' started by ut1205, Jan 30, 2010.
  1. ut1205
    ut1205 New Member
    Jul 4, 2009
    70
    I've been looking at Gasbike's site. Given that they both appear to use the same engine what makes the 4G-T belt drive worth $100.00 more than the "Storm Kit".
    .shft.
  2. HoughMade
    HoughMade New Member
    Apr 15, 2008
    624
    A quieter gearbox that is less likely to self destruct.
  3. ut1205
    ut1205 New Member
    Jul 4, 2009
    70
    Thanks for the reply. Based on that, may I assume that the EZ Motorbike kit that cost twice (correct me if I am wrong on the cost) what the 4G-T kit does is for the same reason? I understandthat EZ gearbox is "US Made"
  4. HoughMade
    Apr 15, 2008
    624
    From all accounts, the the EZM works well, but I have no personal experience with it. I do not think that anyone could say, at this point, that one is more dependable than the other (EZM v. 4G). The "Storm" gearbox, which is a Hoot, has a long and not very glorious history. The EZM is made in the U.S.A.
  5. WayneC
    WayneC New Member
    Aug 2, 2009
    173
    Why not look into the CVT to mount up to that engine. That way you get the best of both worlds for
    <$75 for the CVT. You get the belt primary drive like the others AND the advantage of multiple
    gear range from 7:1 (low) to 3.5:1 (high) primary! Do what you want with the secondary depending on
    bike/rider weight, terrain, city or rural.
    Just another (often overlooked) option. And no, I'm not a dealer, seller, vendor.
    WC
    cvlt1
  6. HoughMade
    Apr 15, 2008
    624
    Need and adapter to get the clutch to work, then it's wide and drives on the right side, same as the pedal chain...or backwards on the left. Would like to see one work, though.
  7. WayneC
    WayneC New Member
    Aug 2, 2009
    173
    http://motorbicycling.com/f36/cvt-rack-mount-7265.html
    Later in the thread he describes using the HS instead of the pocket bike engine.
    http://motorbicycling.com/f15/wayback-machine-12938.html
    Although the OP started with a Subaru and later converted to a 2 stroke. The mounting
    to the engine is the same 4 bolt pattern and clutch size.
    Left drive OR right. Left drive needs no special mounting adapters to correct for direction
    of rotation. Right drive only needs spacer for pedal AND engine drive sprockets to work together.
  8. HoughMade
    Apr 15, 2008
    624
    I like your builds, but I am only interested in frame mount, not rack...and therein lies the CVT conundrum.
