49cc 4G T Belt Drive ??????
Discussion in 'Motorized Bicycle General Discussion' started by toker_ace, Jan 21, 2010.
  1. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    I was reading on the Grubee website and it said as of Jan.1 2010 no china factories are able to meet the new EPA standards.So, I guess i need to start looking into the 4 strokers.Anyone tried the new 49cc 4G T Belt Drive.Whats the verdict?
  2. troyboy
    troyboy Your East Coast Gasbike Connection
    Apr 18, 2009
    171
  3. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    i saw those. just wondering what owners are saying. thanks
  4. Finfan
    Finfan New Member
    Aug 29, 2008
    871
    Geee Grubee is now pushing 4-stroke kits. Suddenly the 2 strokes will no longer be able to meet EPA standards (according to Grubee). Coincidence? I think not!
    Grubee puts out an EPA scare on an yearly basis trying to drum up business. Don't take it too seriously.
  5. MaxPower
    MaxPower New Member
    Jul 1, 2009
    552
  6. toker_ace
    toker_ace Member
    Oct 15, 2008
    475
    must have not sold many. huh?
  7. HoughMade
    HoughMade New Member
    Apr 15, 2008
    624
    Grubee has been selling 4 strokes for years....this kit is very new, but Grubee 4 strokes are not.
  8. recumbentbill
    recumbentbill New Member
    Jul 5, 2009
    87
    I just installed a 4G on my huffy cranbrook cruiser. Here is my 2cents. Firstly there are two g4 drives.The Hausheng and the honda. The Hausheng is wider, Has bearings in the clutch bell housing vers the honda bushing on the clutch bell housing. A output shaft with ten tooth sprocket is offered for both units. Beware--- the Hausheng shaft and the honda shaft are not one in the same. the hausheng's shaft bearings are spaced further apart than the honda unit. I found this out the hard way when I ordered the honda unit with the 10 tooth non free wheel sprocket. I assumed the correct shaft would be with the order. NOT... The dealer was not aware of the differences between the two units. Also my dealer doesn't carry the honda G4 10 tooth solid output shaft[Bummer]. next
    and this was the result of my dum dum After I installed the honda unit on my Honda clone [Hausheng 142F] I decided to go for a test ride. I noticed that when I started the engine the clutch engaged even though I lowered the idle speed. I checked out the centrifical shoe/weights and thought maybe they needed stronger springs .Then I thought that maybe the clutch bell was out of round. Later that day I thought maybe the bushing could use a little grease---Eureka . I'm running a 56 tooth rear free wheel sprocket on the grubee HD axle. Man does this setup pull the hills but at a price. Rather slow but no pedalling even from a dead start.the unit is very quite and ther is no belt slippage at all. A 48 tooth sprocket is on the way and is the smallest my dealer sells for the Grubee HD axle. If the 48 is still to slow I will install my new [on the way] workman 11gauge wheel with a manic mechanic clam shell sprocket adapter for manic mechanics wide range of sprockets . All in all I really like this setup.In the past three days I have logged on 150+ trouble free miles. When the 2010 upgrades are avail I will go with the smaller ratio of 4 to 1. Just remember if you have a stage three kit with the 49cc Hausheng 142f engine with 5/8" drive shaft you will need the Honda G4 unit. PS Almost forgot to add this concerning the honda unit. I thought the unit would have the mounting bolts..WRONG. So go to a good hardware store and get 1/4 x 28 allen cap bolts that are 1" long no lock washers or washers.Put a drop of blue loctite on the threads.
    BLAH BLAH BLAH
    Hope this helps someone .duh.
  9. recumbentbill
    Jul 5, 2009
    87
    Re: 49cc 4G T Belt Drive ?????? update
    Just found out grease on the bushing is not good. Don Grubee said that the bushing needs to be soaked in oil for 24 hrs. I did it and now the bike idles like it should.Standing still take off is smooth and quite usflg
  10. Steve M
    Steve M New Member
    Nov 27, 2009
    73
    Hey Recumbentbill I purchase the 4g with the Hausheng 142F. And I was wondering do I need to soak the bushing in oil if you know? Thanks, Steve.
  11. recumbentbill
    Jul 5, 2009
    87
    Yes. Did mine after I talked to Don Grubee. A must procedure. without the oil the clutch bell does not spin freely
  12. civlized
    civlized New Member
    Apr 28, 2009
    690
    Hey, recumbentbill, does your freewheeling sprocket have 5 bolt holes? I have the HD axle kit from bicycle-engines with all three sprockets, 56t, 48t, 44t. I don't know if it is the same mounting dimensions, but there is a 44t available for some.
  13. recumbentbill
    Jul 5, 2009
    87
    Yes it has 5
  14. civlized
    civlized New Member
    Apr 28, 2009
    690
  15. recumbentbill
    Jul 5, 2009
    87
    Yeah I know . Been dealing with Jeremy for a while now. The 48t should be here friday
  16. abikerider
    abikerider New Member
    Jul 7, 2008
    219
    Hi, just wondering if you ever found a dealer that does carry the G4 output shaft for the 10 tooth sprocket for the Honda. This would be a deal breaker for me as the 11 tooth freewheel sprocket is unreliable.
  17. recumbentbill
    Jul 5, 2009
    87
    Bicycle-engines.com Should be getting some of the honda shafts. Youmight need a rear free wheel HD axle.
  18. ocscully
    ocscully New Member
    Jan 6, 2008
    373
    You can make the 11t freewheel into a fixed sprocket simply by welding up the seam. I did this on my recent build using the Grubee III gearbox with the 11t freewheel and the new SBP 4-stroke shift kit.
    ocscully
  19. Whizzerd
    Whizzerd New Member
    Nov 20, 2009
    101
    Hi Toker, like your avatar. Good looking bike. I've got 60 miles on a HS/4G with no engine or gearbox issues. Smooth & quiet. FWIW, this is a wide and heavy unit. My Felt '1903' was a sweet pedaling bike until I installed the engine. Now it's like trying to pedal a mule! The EZM 4-sroke kit is out now and the Firebelly unit looks very promising. SBP has released a 4 stroke shift kit as well. I'd give serious consideration to all possibilities if had it to do again. Hope this helps.
