44T sprocket diameter too small
Discussion in 'Motorized Bicycle General Discussion' started by gobiewankenobi, Sep 10, 2009.
  1. gobiewankenobi
    gobiewankenobi New Member
    Sep 9, 2009
    9
    The sprocket, in the kit that's yet to arrive, has an inner diameter of 3.7cm. The hub that it needs to go onto is more like 5cm.
    How can I go about enlarging this hole? Or is there a replacement sprocket that I can get that will work? The bike is an older cruiser model, 3 speed internal gear hub with coaster brake.
    Thanks.
    #1 gobiewankenobi, Sep 10, 2009
  2. RedB66
    RedB66 New Member
    Dec 28, 2007
    1,023
    It depends on your resources. You can dremmel the hole larger, hand file or stick a found file in your drill chuck. Just be sure to keep the hole even.
  3. Venice Motor Bikes
    Mar 20, 2008
    6,176
    I once used a cutting torch & a fat round file, because it was going on a really big hub!!
    It helps to first draw the new hole size with a felt marker, (to keep the hole even & centered)
  4. Coval_PL
    Coval_PL New Member
    Jul 28, 2009
    57
    I've got the same problem. I want to apply new wheels with Sram S7 gear-hub, but it's a lot bigger than standard hub. Making bigger hole or drill new holes for bolts is not so difficult but what about rubber and steel mounting parts? I have no idea how to do those mounting parts.
  5. NEAT TIMES
    NEAT TIMES New Member
    May 28, 2008
    1,964
    if you have the money to spare "manic mechanic" has the best set up around. he advertises on the side column of this forum. check out the pictures. you have to order the one to fit your hub.GOBIE, I`M FROM EAU CLAIRE, WI. BEEN DOWN HERE 20 YRS. WHAT TOWN ARE YOU IN. LATER RON .cvlt1
    #5 NEAT TIMES, Sep 11, 2009
  6. city of angels
    city of angels New Member
    May 24, 2009
    470
    go to usa bike motors.com web site they sell the hub the sproket kit for around 75. bucks plus tax this set up will prevent you from drilling holes ir putting tension on the spokes the only thing you have to go to a bike shop to get it re spokes plus this also will give you a brake set up
  7. gobiewankenobi
    Sep 9, 2009
    9
    I'm down in Madison. I'm hoping that this will help me do some commuting but, if nothing else, it'll be fun to play with.
    While Manic Mechanic's setup looks great, I don't have that much money to play with. I'll probably try to find a machinist in town that will mill out the hole to 50mm. I'd do it myself, but I'm having trouble finding a bit large enough.
