4 stroke SHAKE..Help
Discussion in 'Motorized Bicycle General Discussion' started by gokart25, Dec 1, 2013.
  1. gokart25
    gokart25 Member
    Sep 26, 2011
    247
    maybe some of you can weigh in on this...
    At low end my newly built 79cc 4 stroker shakes like crazy.
    Once it gets rolling, it's fine.
    AGK jackshaft (11 tooth, 28, 9, 48)
    Max Torque Clutch
    26" wheel
    Any ideas??
  2. MotorBicycleRacing
    Jul 28, 2010
    5,738
    39
    It's the centrifugal clutch vibrating before it locks up.
  3. runnermike
    runnermike New Member
    Nov 18, 2012
    936
    Is the shaking normal? I'm in the process of building the same engine and setup. GoKart, what stall clutch are you using? What is your top speed with the 48t and why didn't you go with the 56t?
  4. gokart25
    gokart25 Member
    Sep 26, 2011
    247
    The top speed with the 4 stroke has been 36 mph.
    Then I switched to a 28 tooth on the jack-shaft to get the ratio closer to what AGK shows on their site.
    The clutch is Max Torque Clutch engages at 2700 rpm
