2nd kit in 6 years
Discussion in 'Motorized Bicycle General Discussion' started by OzzyU812, Oct 6, 2015.
  1. OzzyU812
    OzzyU812 New Member
    May 15, 2008
    258
    I feel like noob!
  2. 2door
    2door Moderator
    Staff Member
    16,301
    25
    Sure good to see you, Oz. It's been a while. How've you been?
  3. OzzyU812
    OzzyU812 New Member
    May 15, 2008
    258
    Up down in and out
    Good to see a familiar face!
    Things still pretty active here? Do you think Motorized bikes are more popular now? Seems to be lots of groups on Facebook. Been hitting those some.
    Got a Cheez kit. Came with lots of things you had to find or upgrade later
  4. Davezilla
    Davezilla New Member
    Mar 15, 2014
    2,708
    Welcome back... Ive heard some good stuff about those cheez kits.... keep us posted on how it works out for you.
  5. OzzyU812
    OzzyU812 New Member
    May 15, 2008
    258
    It's ALIVE!!
    Used old NT carb because I knew it was working. Poorly but working.
    Old muffler because I had bent it to tuck in tighter.
    Used old clutch cover assembly. Because I couldn't find the screw for tgr built in cable stop. Then it occurred to me, it's probably the one in the cable stop on the clutch wire.
    Didn't want to start took off air cleaner to spray starting fluid. In the process broke it. Hence the new low profile look. I really had it on there. Had jiggling off trouble. Still no start, so I swapped my NGK B7HS with whatever was in the kit. Nothing. Swapped to my Old head. Then it ran!
    I do have a question. It was revving out of control. By the time I got the screwdriver and was turning, what I think is the idle screw. It sounded like it was going to blow. So I killed it. I'd like to confirm that the idle screw is the one next to the primer and which way turns down the idle?
    ( couldn't post pics from mobile. I'm sure you can just don't know how)
  6. 2door
    2door Moderator
    Staff Member
    16,301
    25
    The idle speed screw: Turn it in, clockwise, to increase idle speed, turn it out, counterclockwise, to decrease idle. Idle speed can change slightly depending on engine temperature.
    My suspicion is that there's something wrong with your throttle. Maybe cable adjustment or the throttle barrel is sticking or installed backwards.
  7. Dan
    Dan Staff
    Staff Member
    May 25, 2008
    12,495
    50
  8. MacZulu
    MacZulu New Member
    Jul 3, 2015
    127
    I just stalled a cheez kit, very good kit. like you said, alot of little upgades. mine started first time with out much trouble, but as I was riding I adjusted the idle screw and a little while later I lost the idle screw. i guess i backed it off a little too much. I put on my sha clone (dakar version with the air screw and idle screw) and runs like crap. so I asked Legwon about it and he pointed out its a scooter carb and the jet is probably too big, so in a few minutes im going to take the jet from the stock and put it in the sha.
    but ya, love the kit
  9. OzzyU812
    OzzyU812 New Member
    May 15, 2008
    258
    Dan! Was wondering if you was still here. Staff now! :) how's happy?
    Still smell a hint of bacon
    You ever get your 29er?
    I'm a beekeeper now!
    2door
    Confirmed the direction at Cheez bikes on FB. And Don was thinking thr cylinder was upside down. Which it wasn't. Going to put the speed carb and all other associated parts on.
