250+ Lbs frame and wheels recommendations
Discussion in 'Motorized Bicycle General Discussion' started by Master-shake, May 30, 2013.
  1. Master-shake
    Master-shake New Member
    Feb 24, 2013
    315
    Hey guys this is the shake here,
    I've been trying to start selling these motorbikes as secondary set of income. I like talking to the customers and what not, and I got this one that has a little weight issue that they are currently working on. They can't drive a vehicle for reasons I'm not willing to disclose. Basically, we have a big 5'2" person who needs a little info with regards to weight limits on these bikes.
    I can build her one, but I need to know if any of you guys have any keen insight on the tires/frames/rims I should avoid entirely or look more into. I've been told that my jet black moto can carry 240lbs up a hill somewhere but I don't wanna extend this statement to a customer at 275.
    Any tips, advise on tires or frames to be looking out for?
    Is she gonna need some special tires or what?
    Budget is looking from 500-1000.
    Links appreciated.
  2. Highwaystar
    Highwaystar Member
    Jan 22, 2012
    263
    Worksman wheels and a big rear sprocket.
  3. wheelbender6
    wheelbender6 Active Member
    Sep 4, 2008
    3,819
    11
    Husky makes good wheels too. I think most any frame is strong enough but it's probably better to go with steel.
  4. Kioshk
    Kioshk Active Member
    Oct 21, 2012
    1,153
    Me+backpack+bike = 340 lbs.
    Walmart Two Nine = $200
    X80 Kit = $140
    56T drive sprocket = $20
    Cruises @ about 23 MPH
    Mount the engine properly; aluminum's plenty strong.
    P.S.:
    step-ladder = $10 (so shorty can mount the bike)
    comfort-seat = $25 (for her large posterior)
    #4 Kioshk, May 30, 2013
  5. maniac57
    Oct 8, 2011
    4,486
    I agree with Kioshk. A decent set of alloy rims should hold up just fine. I have untold miles on mine and I am usually 250-275 lbs...plus I've been known to carry a #85 lb welder in the basket. I've gone through many tires but never had a rim issue. I use a stock ragjoint properly setup and have never broken a single spoke or bent a rim. A sprocket adapter is the easiest way to get a reliable driveline, but the stock parts work fine if correctly assembled.
  6. Moto
    Moto Member
    Jan 7, 2012
    399
    All that said I would go with a high quality STEEL frame from a reputable seller. (And good brakes - especially if she isnt used to riding a lot)
  7. 5-7HEAVEN
    5-7HEAVEN Well-Known Member
    Aug 2, 2008
    2,364
    37
    Maybe this short, heavy person would be more comfortable on a three-wheeler.
    No disrespect meant whatsoever. Just trying to help find something that'd work for her.
  8. racie35
    racie35 Active Member
    Nov 17, 2012
    1,700
    You should buy a used whizzer
  9. Venice Motor Bikes
    Mar 20, 2008
    6,175
    My suggestion is to use a steel Felt cruiser & Worksman wheels.
    I used this combo for a 350lbs+ customer a few years ago & he's never had a problem. ;)
  10. LR Jerry
    LR Jerry Active Member
    Dec 19, 2011
    1,027
    I'm 6'2" and 250 lbs. A steal frame is a must. 2" double walled rims. Extra thick slime intertubes. I personally use a Staton Inc hub. Seat and front suspension. If there are steep hills to contend with consider a shiftkit. Most important of all lookup and read the person's local laws before buying and building anything.
    #10 LR Jerry, May 31, 2013
  11. Allen_Wrench
    Feb 6, 2010
    2,787
    I'm kinda siding with the people who recommend good steel frames. I've worked with and welded aluminum, and it can handle quite a bit. But we're looking at above-average weight and payload in addition to vibration. This is right up steel's alley.
    And I love Worksman wheels; they're the greatest. You'd be glad you got 'em once you tried 'em. And a 52T (or bigger) sprocket will make the engine's life easier.
    And I would also say try to find the best brakes you can afford. She'll thank you for that.
  12. Master-shake
    Feb 24, 2013
    315
    I'm going to go with the worksman wheels I'm sure. As for the frame, I have a two-nine genesis shimano frame. I have it in stock. Thanks for your suggestions guys. And the link! I'm getting her in here soon for a mock up fitting to see if this style and size bike are what she needs.
    Thanks again.
    I look forward to the day someone commissions a felt, alas this is not that build.
  13. maciver02
    maciver02 Member
    Jul 3, 2012
    90
    I concur; Worksman is the BEST way to go here!
