2011 grubee 48cc
Discussion in 'Motorized Cruiser Bicycles' started by Greg58, May 11, 2011.
  1. Greg58
    Greg58 Well-Known Member
    May 1, 2011
    2,841
    59
    I built another bike last night using a 2011 48cc grubee. The first thing I noticed was the square cyld. head like the 66cc , longer clutch arm with a slight bend to tuck the arm in under the carb better. clutch cable boss is machined in the crankcase at a better angle. Also a redesigned exhaust port angle. I moved the e-clip on the needle to the bottom slot before installing the carb. It started right up! I noticed right off that this engine has much better mid range torque, also it seems that grubee has worked out the bugs in the cns carb because this one runs great! The only adjustment I made was lowering the idle. It sounds like someone is reading the complaints!
    #1 Greg58, May 11, 2011
  2. darkhawk22
    darkhawk22 New Member
    Aug 17, 2010
    733
    Thanks for the update on the 2011 engine!
  3. F_Rod81
    F_Rod81 Dealer
    Jan 1, 2011
    1,033
    Not bad, looks good
  4. SupaBaked
    SupaBaked New Member
    May 8, 2011
    19
    Nice, I am going to get a new bike and engine soon. Would you recommend this engine? Why not get the 80cc or the 66cc? Your bike kicks ass.
  5. F_Rod81
    F_Rod81 Dealer
    Jan 1, 2011
    1,033
    The 80cc and 66cc are one in the same my friend. 80cc is used for marketing purposes only, the actual engine displacement is 66cc. I use the bigger 66cc Grubee Skyhawk angle-fire series. All kits are about the same, it's the modifications you do that will make a difference. Best of luck with your project, let us know if we can help.
  6. Greg58
    May 1, 2011
    2,841
    59
    The engine size for me was decided by the Ga. dmv. We have to stay under 50cc to avoid registration, since I built my bike we have built five of the 48cc grubee's. We get a-lot of thumbs up when we ride.
  7. sketchman
    sketchman New Member
    Mar 23, 2011
    168
    So where do you find one of these '11 kits? Everything I see says '10 model.
  8. darkhawk22
    Aug 17, 2010
    733
    Hey Greg, what part of GA, I'm up in the northwest near Marietta/Cartersville. You're right I believe all we need is to have less than 50cc and a DOT helmet and a standard drivers license. I haven't ridden on the main roads much due to lack of visibility (mountains and corners) but have not had any issues with local police etc.. I actually have a 66cc kit but for all practical purposes it's externally the same as a 49cc so I have labeled it as a 49cc.
  9. Greg58
    May 1, 2011
    2,841
    59
    I am between Newnan and Peachtree City.
  10. Greg58
    May 1, 2011
    2,841
    59
    The best i can tell the model year change over was mid. october, the one I built was dated sept. 2010 the one I did this week was oct. 20 2010.
  11. SupaBaked
    May 8, 2011
    19
    I heard that the only way for the cops to know weather you have a 49cc or 80cc is to take the engine apart. So they never know anyway if your engine is bigger. Any truth to that?
  12. Greg58
    May 1, 2011
    2,841
    59
    I have heard that you must have the epa rating decal on the engine that states the engine size, besides my 48cc will go faster than I want to ride a bike anyway. I am trying to obey the law.
    Honesty is doing right when no one is looking!
  13. SupaBaked
    May 8, 2011
    19
    OK, point well taken. I have also heard the 48cc is enough power as well. But not sure I can resist getting a bigger engine. I don't equate man made lawswith weather a person is honest or not. As I drive over the speed limit almost everywhere I drive my truck;)
  14. Greg58
    May 1, 2011
    2,841
    59
    Around here as I ride by seams everyone notices what I am riding, If regular people notice then I would think a officer would do the same. I don't want the heat thats all.
  15. SupaBaked
    May 8, 2011
    19
    Yes I am very lucky it seems to live where the cops don't really have time to care. Thanks for the tips, I really like this site!
  16. txlixard469
    txlixard469 New Member
    Feb 21, 2011
    72
    I had a cns carb and the biggest problem I had was the plastic on the inner clamp became to hot and melted . Have you or anyone else had this problem I have had two and the same problem the nt carb i did not have that problem cuz they had a medal clamp.
  17. Greg58
    May 1, 2011
    2,841
    59
    I have not had any heat issuses, sounds like a lean condiction causing the heat.
  18. txlixard469
    Feb 21, 2011
    72
    lean condition?
  19. Greg58
    May 1, 2011
    2,841
    59
    if the air to fuel ratio is lean the engine will run hoter, one problem we sometimes overlook is the ethnol in our fuel.
