2 Engines Twice the Vibration?
Discussion in 'Motorized Bicycle General Discussion' started by recon chris, Sep 12, 2012.
  1. recon chris
    recon chris New Member
    Apr 28, 2011
    87
    I'm thinking of mounting two engines on one bike. They will both be automatic clutch engines of the same type. I was wondering if the lack of linkage between the two engines will cause them to run in and out of ocolation with eachother poably amplifying vibrations?
  2. Bikeguy Joe
    Jan 8, 2008
    11,529
    That is entirely possible. You'll just have to use two throttles, and sync them up like a twin engine plane.
  3. Ludwig II
    Ludwig II Well-Known Member
    Jul 17, 2012
    4,769
    68
    One of the cable splitters (1 cable goes in, 2 come out) used on 2 strokes with an oil pump will have them opening and shutting together. It's just a matter then of small adjustments of them to work absolutely together.
  4. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    this is a cool idea
  5. Ted
    Ted New Member
    Apr 20, 2010
    208
    Recently I saw a show where a guy had 2 V8's in a hot rod, he said his biggest problem was syncing the engines which is extremely important because one engine can/will destroy the other. Now then,,if this would apply to 2 two cycle engines I don't know. he ended hooking up the engines together and were phased to fire opposite of each other.
    FWIW Honda used a twin cable throttle control that was controlled by a single cable.
  6. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    its easier for a car because if you start with marine engines because they come in both rotations you can make then counter rotate with each other
  7. Ted
    Ted New Member
    Apr 20, 2010
    208
    Well that's true but they have separate drives and are independent of each other.
    I do wonder however that if the bike engines were hooked together 180 deg's to each other if vibrations would be canceled out.
    #7 Ted, Sep 14, 2012
  8. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    in the v twin posts there are pics of a twin engine bike
  9. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    im currently looking into the multi cylinder options they are throwing out there
  10. rustycase
    rustycase Gutter Rider
    May 26, 2011
    2,746
    there's pics here on the board of a side-by-side HT powered bike...
    ???double trouble???? search might bring it up???
    a member built it.
    rc
  11. Ted
    Ted New Member
    Apr 20, 2010
    208
    V Twin?? can't find it.
  12. rustycase
    May 26, 2011
    2,746
    NO, it's a side-by-side... and they run to a common jackshaft.
  13. JonnyR
    JonnyR New Member
    May 13, 2012
    1,203
    they are posting twin uprights there im thinking about one if the power and money is right
  14. lowracer
    lowracer New Member
    Oct 17, 2008
    1,319
